Motorola TLKR T7 2-Way Radio Pack - Black
Quicklinx: 5H9NWS00 Mfr#: P14MAB03A1AP
The Motorola T7 is a high performance walkie-talkie for the extreme sports enthusiasts who need reliable two-way communications for their adventures. The Motorola T7 is easy to use and carry, yet it is a high specification radio that comes with features for more effective communication with your team members.
  • Direct call
    Lets you call everyone in your group at once, or call a single person in your group without anyone else in the group knowing. It is like a "speed dial" directly to the person(s) you want to talk to.
  • Caller ID
    You can set a nickname which appears on other units' displays when you make an "all call" or "direct call". This is also the name that appears on other radio displays when someone wants to make a direct call to you.
  • Auto channel change
    Lets you easily coordinate a channel change for everyone in your group. You might want to do this should you experience interference on your current channel.
Motorola TLKR T7 two-way radio - PMR
Two-way radio
Packaged Quantity
2 (specifications are for single item)
Portable
Channels
8-channel
0.5 watt
Max Talk Range
10 km
Call Alerts
10
Vibrating Alert
Voice Operated Transmission (VOX)
Internal (iVOX)
Display
LCD display backlit
Rechargeable - Nickel Metal Hydride
Run Time (Up To)
16 hour(s)
5.4 cm x 3 cm x 20.2 cm
178 g
Grey
United Kingdom
Packaged Quantity
Two-way radio
Two-Way Radio Form Factor
Portable
5.4 cm
3 cm
20.2 cm
178 g
Body Colour
Grey
United Kingdom
Radio System
PMR
Channels
8-channel
0.5 watt
Max Talk Range
10 km
Call Alerts
10
Vibrating Alert
Controls
Push-to-talk (PTT) button
Display Information
Battery level indicator
Sub-Channels Qty
121
Radio System Features
Internal (iVOX)
Channel Scan
Audible Call Alert
Keypad Lock
Keystroke Tone
Time-Out Timer
Additional Functions
Countdown timer
Additional Features
Auto squelch, Babyphone (room monitoring), licence-free
Display
LCD display
Backlit
Aerial
External
Headset jack - mini-phone 3.5mm
Belt clip, power adapter, dual charging stand
FCC Licensing Requirements
Not required
Dual charging stand + power adapter
Run Time (Up To)
16 hour(s)
Audible Battery Alert
