Trusted security & easy manageability
Your business data and mobile platforms are secured by ThinkShield® for mobile. AI-based defence systems, government-grade certifications, trusted suppliers, vetted manufacturing processes, and a dedicated incident-response team deliver 360° protection.
Deploy ThinkPhone right out of the box with zero-touch enrolment. Manage your entire fleet from a single location and create a customised experience for your organisation.
Kept in confidence
Device hardware, firmware, and software are integrated to protect your most sensitive data from mobile threats. With Moto KeySafe, PINs, passwords, and cryptographic keys are isolated from other device data for an added layer of high-level security.
Built for where your business takes you
Take whatever work throws at you with impact-resistant Gorilla® Glass Victus™ display protection. MIL STD 810H-tested1 for durability, ThinkPhone is crafted from aramid fibre that is stronger and lighter than steel, with an aircraft-grade aluminium frame. It’s also IP68-certified to withstand dust, dirt, sand, and submersion in shallow water
ThinkPad's perfect companion
Expand your mobile workspace and enjoy seamless connection to your PC with ThinkPhone. Integrating Android and Microsoft Windows experiences, your organisation can take productivity to new heights. Just double tap the iconic Red Key to easily sync to your ThinkPad or PC. You can even customise a single tap to open any app you choose.
App Streaming
Make your mobile experience part of your desktop experience. Open mobile apps directly on your PC for easy platform integration.
File Drop
Transferring files between ThinkPhone and your PC is as simple as dragging and dropping.
Advanced Webcam
Stay front, centre, and looking sharp on video calls with AI-informed, movement-tracking camera capabilities.
Unified Notifications
Phone notifications appear instantly in the Windows Action centre, so you can answer a call or reply to messages right from your PC.
Your business data and mobile platforms are secured by ThinkShield for mobile. AI-based defense systems, government-grade certifications, trusted suppliers, vetted manufacturing processes, and a dedicated incident-response team deliver 360° protection. Deploy ThinkPhone right out of the box with zero-touch enrolment. Manage your entire fleet from a single location and create a customised experience for your organization. -
Kept in confidence
Device hardware, firmware, and software are integrated to protect your most sensitive data from mobile threats. With Moto KeySafe, PINs, passwords, and cryptographic keys are isolated from other device data for an added layer of high-level security. -
Take whatever work throws at you with impact-resistant Gorilla Glass Victus display protection. MIL STD 810H-tested for durability, ThinkPhone is crafted from aramid fiber that is stronger and lighter than steel, with an aircraft-grade aluminum frame. It's also IP68-certified to withstand dust, dirt, sand, and submersion in shallow water. -
Expand your mobile workspace and enjoy seamless connection to your PC with ThinkPhone. Integrating Android and Microsoft Windows experiences, your organization can take productivity to new heights. Just double tap the iconic Red Key to easily sync to your ThinkPad or PC. You can even customise a single tap to open any app you choose.
 - Motorola ThinkPhone - carbon black - 5G smartphone - 256 GB - GSM
- Product Type
 - 5G smartphone
- Display
 - pOLED display - 2400 x 1080 pixels - 6.55" - 402 ppi - (144 Hz) - 20:9 - P-OLED - HDR - Corning Gorilla Glass Victus (scratch resistant glass)
- Processor
 - Qualcomm Snapdragon 8+ Gen 1
- Memory
 - RAM 8 GB / 256 GB
- Operating System
 - Android 13 with My UX
- Main Camera
 - 50 Megapixel - f/1.8 - focus: automatic
- Second Camera
 - 13 Megapixel - ultra wide-angle lens - f/2.2 - macro camera
- Third Camera
 - - depth camera
- Front Camera
 - 32 Megapixel f/2.45 - automatic
- Service Provider
 - Not specified
- SIM Card
 - Dual-SIM - nano SIM
- Wireless Interface
 - NFC, Wi-Fi 6, Wi-Fi 6E, Bluetooth
- Security Devices
 - Fingerprint reader (under display)
- Connectors
 - USB-C
- Protection
 - Water-resistant, splash-resistant, dust-resistant
 - Carbon black
 - 74.38 mm x 8.26 mm x 158.76 mm
 - 189 g
- Specific Absorption Rate (SAR)
 - 0.94 W/kg (head) , 1.26 W/kg (body) , 2.52 W/kg (limb)
 - 2-year warranty
- Product Type
 - Smartphone
- Form Factor
 - Touch
- Protection
 - 74.38 mm
 - 8.26 mm
 - 158.76 mm
 - 189 g
- Body Colour
 - Carbon black
- Body Material
 - Aircraft-grade aluminium, aramid fibre
Cellular
- Technology
 - WCDMA (UMTS) / GSM
- Mobile Broadband Generation
 - 5G
- Service Provider
 - Not specified
- Operating System
 - Android 13
- User Interface
 - My UX
- Intelligent Assistant
 - Google Assistant
- Navigation
 - GPS, A-GPS, GLONASS, Galileo, LTEPP, SUPL
- SIM Card Type
 - Nano SIM
- SIM Card Qty
 - Dual-SIM
- Input Device
 - Multi-touch
Communications
- Data Transmission
 - LTE, 5G NR FR1
- 3G UMTS Band
 - Band 1, Band 2, Band 4, Band 5, Band 8, Band 19
- 3G UMTS Frequency
 - 2100, 1900, 1700, 850, 900, 800
- 4G LTE Band
 - Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 18, Band 19, Band 20, Band 25, Band 26, Band 28, Band 32, Band 38, Band 39, Band 40, Band 41, Band 42, Band 43, Band 48, Band 66
- 4G LTE Frequency
 - FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 1900+, FDD 850+, FDD 700 APT, FDD 1500 L, TDD 2600, TDD 1900, TDD 2300, TDD 2500, TDD 3500, TDD 3700, TDD 3600, FDD 1700 - 2110 AWS-3
- 5G NR Band
 - N1, n2, n3, n5, n7, n8, n20, n28, n38, n41, n66, n77, n78, n40
- 5G NR Frequency
 - FDD 2100, FDD 1900PCS, FDD 1800, FDD 850, FDD 2600, FDD 900, FDD 800, FDD 700APT, TDD TD 2600, TDD TD 2500, FDD AWS-3, TDD TD 3700, TDD TD 3500, TDD 2300
 - NFC, IEEE 802.11a/b/g/n/ac/ax, Wi-Fi 6E, Bluetooth 5.3
Phone Features
- Sensors
 - Accelerometer, ambient light sensor, proximity sensor, SAR sensor, gyroscope
- Security Devices
- Security Technology
 - ThinkShield for Mobile, Moto KeySafe
- Additional Features
 - Dual microphones, Gesture Controls, Android Sensor Hub, Media Control, DisplayPort over USB Type-C, dual stereo speakers tuned by Dolby Atmos, App Streaming, File Drop
Media Player
- Sound Enhancements
 - Dolby Atmos sound technology
- RAM
 - LPDDR5 SDRAM - 8 GB
- Internal Memory Capacity
 - 256 GB
- Memory Interface
 - UFS 3.1
Front Camera
- Sensor Resolution
 - 32 Megapixel
- Lens Aperture
 - F/2.45
- Focus Adjustment
 - Automatic
- Pixel Size
 - 0.7 µm
- Special Effects
 - HDR, Live Filters
- Camera Modes
 - Timer mode, BurstShot, Watermark mode, Video Snapshot, Face Beauty, Active photos, Selfie Mirror, Portrait, Group selfie, video filters, Auto smile capture, Spot colour, Capture Dual, Gesture Capture, Timelapse with Hyperlapse, Professional (with Long Exposure), Auto night vision
- Video Resolutions
 - 1920 x 1080 (1080p) at 30 fps, 1920 x 1080 (1080p) at 60 fps, 3840 x 2160 (4K) at 30 fps
 - Video image stabilisation, RAW photo, Quad Pixel technology for 1.4 µm, levelling, Selfie animation, Assistive grid, Shot Optimisation
Main Camera
- Sensor Resolution
 - 50 Megapixel
- Sensor Size
 - 1/1.5"
- Optical Image Stabiliser
 - Optical Image Stabiliser (OIS)
- Lens Aperture
 - F/1.8
- Pixel Size
 - 1 µm
- Focus Adjustment
 - Automatic
- Self-Timer Delay
- Special Effects
 - HDR, Live Filters
- Camera Modes
 - BurstShot, Watermark mode, Video Snapshot, 360 Panorama mode, Super Slow-mo, Active photos, Portrait, Night Vision, AR stickers, Levelling, video filters, Spot colour, Ultra-Res, Capture Dual, Scanner, Pro mode with long exposure, Timelapse with Hyperlapse, Auto night vision
- Face Detection
 - Auto smile capture
- Light Source
 - LED flash
- Video Resolutions
 - 1920 x 1080 (1080p) at 30 fps, 1920 x 1080 (1080p) at 60 fps, Slo-mo video 1920 x 1080 (1080p) at 120 fps, 3840 x 2160 (4K) at 30 fps, 3840 x 2160 (4K) at 60 fps, Slo-mo video 1920 x 1080 (1080p) at 240 fps, Slo-mo video 1920 x 1080 (1080p) at 960 fps, 7680 x 4320 (8K) at 30fps
 - RAW image capture, Barcode Scanner, Cutout, Quad Pixel technology, smart composition, shot optimisation, Google Lens, Assistive Grid, Omni PDAF
Second Camera
- Sensor Resolution
 - 13 Megapixel
- Lens Type
 - Ultra wide-angle lens
- Lens Aperture
 - F/2.2
- Field of View (FoV)
 - 120 degree(s)
- Pixel Size
 - 1.12 µm
- Functions
 - Macro camera
Third Camera
- Functions
 - Depth camera
Display
 - pOLED display
- Technology
 - P-OLED
- Diagonal Size
 - 6.55"
- Display Resolution
- Display Format
 - Full HD+
- Pixel Density
 - 402 ppi
- Aspect Ratio
 - 20:9
- Max Brightness
 - 1200 cd/m²
- Colour Depth
 - 1.07 billion colours
- HDR
- HDR Technology
 - HDR10+
- Refresh Rate
 - 144 Hz
- Touch Sampling Rate
 - 360 Hz
- Protection
 - DCI-P3 Wide colour gamut, attentive display, Peek Display
- Connector Type
 - USB Type-C - 24 pin USB-C
- Capacity
 - 5000 mAh
- Fast Charging Technology
 - TurboPower technology
- Wireless Charging
- Run Time Details
 - Standard usage: up to 36 hrs
 - IP68, DisplayPort 1.4, MIL-STD-810H
- Included Accessories
 - Protective cover, SIM card removal tool, USB-C cable, TurboPower 68W charger
 - Limited warranty - 2 years
