Fully featured, tough and stylish, the T62 walkie-talkie is the ideal way to stay connected during outdoor adventures. At home, on the campsite, at a festival or simply hiking, the T62 keeps you in touch.
- Motorola Talkabout T62 two-way radio - PMR
- Product Type
- Two-way radio - 446 MHz
- Packaged Quantity
- 2 (specifications are for single item)
- Form Factor
- Portable
- Channels
- 16-channel
- Max Talk Range
- 8 km
- Display
- Monochrome
- Battery
- Rechargeable - Nickel Metal Hydride
- Run Time (Up To)
- 18 hour(s)
- 5.4 cm x 3.1 cm x 16.5 cm
- 161 g
- Black, blue
- Packaged Quantity
- Product Type
- Two-way radio
- Two-Way Radio Form Factor
- Portable
- 5.4 cm
- 3.1 cm
- 16.5 cm
- 161 g
- Body Colour
- Black, blue
Radio System
- PMR
- Frequency Range
- 446 MHz
- Channel Spacing
- 12.5 kHz
- Channels
- 16-channel
- Max Talk Range
- 8 km
- Sub-Channels Qty
- 121
Radio System Features
- Channel Scan
- Audible Call Alert
- Keypad Lock
- Talk Confirmation Tone
- Built-in Speaker
- Additional Features
- USB charging
Display
- Monochrome
- Aerial
- External
- Connections
- Headset jack - sub-mini-phone 2.5mm , USB - 5 pin Micro-USB Type B
- Included Accessories
- Power adapter, 2 belt clips, 16 stickers
- FCC Licensing Requirements
- Not required
- Battery Included
- Technology
- Capacity
- 800 mAh
- Run Time (Up To)
- 18 hour(s)
