Motorola PIP12 Portable Audio Baby Monitor with Travel Pouch
Quicklinx: HRC1WS00 Mfr#: PIP12
The perfect travel companion for parents! Crystal-clear HD sound, 10 hours of battery life, and an enhanced 1,500ft range. The portable, magnetic design powers off the units automatically. Rainproof pouch and USB-C charging for convenience. Goodbye hassle, hello peace of mind!
  • The ultimate travel companion
    With crystal-clear HD sound and up to 10 hours of battery life, parents can monitor their sleeping baby without dismantling their monitor setup at home.
  • Ideal for travel
    Purposefully designed to make it easy and convenient for parents to travel with their baby, safe in the knowledge they can monitor their sleeping baby without having to dismantle their existing monitor set-up at home.
  • Unique design with automatic power off
    PIP12 TRAVEL features a unique "yin and yang" magnetic design that joins the baby and parent units together when not in use, and automatically shuts them off to conserve the battery.
  • HD sound
    Experience ultimate peace of mind with HD sound. Crystal-clear audio captures every coo and cry, ensuring you never miss a beat. Respond swiftly and confidently to your baby's needs, making parenting feel easier and more connected.
  • Up to 1,500ft range
    With an extended range of up to 1,500ft you can be sure you are always connected to your little one with a constant, secure and reliable connection.
  • Up to 10 hours battery
    The portable baby and parent unit comes with up to 10 hours of battery life and includes 4 x rechargeable Ni-MH batteries, making it perfect for long trips.
  • Convenient USB-C charging
    The PIP12 TRAVEL comes with the added convenience of USB charging cables and adapters supplied for both the baby and parent unit, making charging on-the-go a breeze.
Motorola Nursery PIP12 TRAVEL baby monitoring system
Baby monitoring system
Components
Baby unit, parent unit
Portable
Max Talk Range
450 m
Rechargeable - nickel-metal hydride - AAA type
Run Time (Up To)
10 hour(s)
5.2 cm x 4.3 cm x 9.4 cm
458 g
1-year warranty
Components
Two-Way Radio Form Factor
Portable
5.2 cm
4.3 cm
9.4 cm
458 g
Radio System
Max Talk Range
450 m
Controls
Power button, volume button
Indicators
Mute
Radio System Features
Additional Features
Out of range alert, Babyphone (room monitoring), Automatic Power Off (APO), USB charging, HD Sound
Aerial
Internal
USB Type-C
Carrying pouch
AAA type
Battery Included
Run Time (Up To)
10 hour(s)
Limited warranty - 1 year
