Your basket is empty
Motorola LS2208 General Purpose Bar Code Scanner Kit USB
Quicklinx: 7G40WS00 Mfr#: LS2208-SR20001R-UR
Type: Barcode scanner
Form Factor: Handheld
Max Paper Size: [N/A]
Compatibility: PC
More than 50 in stock
£49.34 ex VAT
£59.20 inc VAT
The innovative LS 2208 hand-held scanner from Symbol Technologies delivers performance features at an affordable price to make your buying decision easier than ever. If you're seeking investment protection and great value in a small, light scanner that assures maximum productivity, then the LS 2208 is the ideal scanner for you.
From the checkout line to the back room, the LS 2208 helps you make the most of your application-specific solution in a variety of ways.
Getting started with the LS 2208 is fast and simple with 123Scan setup utility. This easy-to-use tool reduces startup time and costs wherever the scanner is used. To further save you money, the scan element in the LS 2208 is based on a liquid injection process that delivers integral shock protection, providing durability you can count on. These powerful features enable you to reduce downtime and keep maintenance costs to a minimum.
In any industry, the high-value LS 2208 hand-held scanner offers superior performance, excellent reliability and user-friendly ergonomics to create a more productive mobile environment. And when you choose the LS 2208, you receive the added assurance of purchasing from Symbol - a company with proven solutions and millions of scanner installations worldwide.
Symbol LS2208 - barcode scanner
Barcode scanner - handheld - USB
Scan Element Type
Visible laser diode
Scan Speed
100 scan / sec
Wired
6.3 cm x 8.4 cm x 15.2 cm
146 g
5 years warranty
Cash register white
Barcode
Interface Type
USB
Scan Element Type
Visible laser diode
Light Source Wave Length
650 nm
Scan Mode
Single-pass
Scan Speed
100 scan / sec
Max Working Distance
43 cm
Skew (Degrees)
60
Pitch (Degrees)
65
Print Contrast Signal (PCS)
20%
Decode Capability
Code 93, Code 39, UCC/EAN-128, IATA, Code 39 Full ASCII, Discrete 2 of 5, Codabar, Code 128, Code 11, UPC, Interleaved 2 of 5, Code 128 Full ASCII, Code 39 Trioptic
Wired
OK Notification
Beeper, LED indicator
Advanced Data Formatting (ADF)
Stand
1 x USB cable
VCCI, ICES-003 Class B, FCC Part 15 B, MITI, EMC, RoHS
Power adapter
6.3 cm
8.4 cm
15.2 cm
146 g
Limited warranty - lifetime
5 - 95%
Drop Specification
1.5 m to concrete
Compatibility: PC
Brand: Motorola
Price Range Ex VAT: 0 - 50
