Your basket is empty
Motorola Handheld Barcode Scanner
Quicklinx: B4MZWS00 Mfr#: LS2208-1AZR0100ER
Type: Barcode scanner
Form Factor: Handheld
Compatibility: PC
£68.53 ex VAT
£82.23 inc VAT
The affordable LS2208 handheld bar code scanner provides fast, reliable scanning in an ergonomic, lightweight form. The wide working range - from near-contact to 17 inches - makes this device ideal for retail, hospital, education or government settings. Multiple on-board interfaces ensure integration with a variety of host systems.
Symbol LS2208 - barcode scanner
Barcode scanner - handheld - RS-232 - decoded
EMEA
Minimum Bar Width
5 mil
Scan Element Type
Visible laser diode
Scan Speed
100 scan / sec
Wired
6.3 cm x 8.4 cm x 15.2 cm
146 g
5 years warranty
Cash register white
EMEA
Barcode
Interface Type
RS-232
Minimum Bar Width
5 mil
Scan Element Type
Visible laser diode
Light Source Wave Length
650 nm
Scan Mode
Single-pass
Scan Speed
100 scan / sec
Max Working Distance
76 cm
Skew (Degrees)
60
Pitch (Degrees)
65
Print Contrast Signal (PCS)
20%
Decode Capability
Code 93, Code 39, UCC/EAN-128, IATA, GS1 DataBar, Code 39 Full ASCII, Discrete 2 of 5, Codabar, Code 128, Code 11, UPC, Interleaved 2 of 5, MSI-Plessey, Code 128 Full ASCII, Code 39 Trioptic
TTL Decoding
Decoded
Wired
OK Notification
Beeper, LED indicator
Triggered, Advanced Data Formatting (ADF)
1 x RS-232 - DB-9
Stand
1 x serial cable - external
Plug and Play, VCCI, EN 60950, IEC950, UL 1950, ICES-003 Class B, FCC Part 15 B, MITI, EMC, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, CSA C22.2 No. 950, IEC 60825-1, CSA C22.2 No. 60950-1, EN 60825-1
Power adapter
Electric Current Required
130 mA (typical), 175 mA (peak)
6.3 cm
8.4 cm
15.2 cm
146 g
Limited warranty - 5 years
50 °C
5 - 95% (non-condensing)
Drop Specification
1.5 m to concrete
Compatibility: PC
Brand: Motorola
Price Range Ex VAT: 50 - 100
