Motorola FW500 Hybrid Back Up Phone for BT/EE Digital Voice Service
Quicklinx: HGJLWS00 Mfr#: 117693
Type: Corded phone
Handsets Included: 1
Answer Machine: [N/A]
Nuisance Call Blocker: [N/A]
Mounting: Table-top
£66.66 ex VAT
£79.99 inc VAT
Express delivery Order within the next 14 hours for delivery tomorrow
The FW500 Hybrid backup phone, gives Digital Voice customers auto switch over to the EE Mobile network if there’s a power cut, or if the Broadband service goes down.
Easy set up
Get the most out of your phone straight away with our easy-to-use menu.
Battery back Up
The phone has up to an 8-hour battery back up in case of a power cut
9 Programmable Speed Dial Keys
Store your important contacts so you can easily reach them with just one button press
Technical support
Available from the BT Helpdesk on 0800 800 150 or via bt.com/help/digital-voice
Type: Corded phone
Mounting: Table-top
Big Button: Yes
Brand: Motorola
Stock Status: While stocks last
Stock Status: Clearance
