Motorola Edge 50 Pro Luxe Lavender
Quicklinx: HW3GWS00 Mfr#: PB1J0007GB
Operating system: Android 14
Model: Edge 50 Pro
Mobile Connectivity: 5G
Screen Size: 6.7in
Rear Camera: 50 Megapixel
£290.84 ex VAT
£349.00 inc VAT
Marketing description is not available.
  • Sync your style
    Easily generate wallpapers and device themes that match your unique style. Just snap a photo of your outfit - or any interesting pattern - and motorola edge 50 pro uses generative AI to produce four one-of-a-kind images. Choose your favorite image and apply it directly to your wallpaper, so your phone and outfit are always in sync.
  • Pantone Validated color
    The motorola edge 50 pro is the world's first smartphone with a Pantone Validated camera and display. Confidently capture and view the world as you see it with Pantone Validated color and skin tones. Every Pantone Validated device has met Pantone's evaluation and grading criteria by authentically simulating the full range of real-world Pantone Colors. Pantone SkinTone Validated assures that what you capture with the camera, or see on the display, truly represents the vast authentic spectrum of human skin tones.
  • Handheld cinema
    See your films and media with over a billion shades of color on a borderless 6.7" pOLED display.
  • Super HD
    Blacks are deeper, colors are brighter, and contrast is infinite thanks to Super HD (1220p) resolution.
  • Silky smooth
    Gaming, scrolling, and app switching are smooth and fluid with an unbelievably fast 144 Hz refresh rate.
  • Feel the sound
    Listen to music as it's meant to be heard, enhanced by Dolby Atmos audio on large, loud stereo speakers. With supported Bluetooth devices, Snapdragon Sound delivers incredibly immersive detail.
  • Power for the day in 4 minutes
    A fast charging means more juice for the things you want to do.
  • Go warp speed
    Get a full charge in as little as 18 minutes with 125 W TurboPower charging.
  • Stay in your zone
    Do what you love longer with a powerful 4500 mAh battery that provides up to 40 hours of power.
  • Edge lights
    Set your edge lights to alert you to incoming calls, notifications, and alarms.
  • Safeguard your sight
    Reduce eye strain with flicker protections and keep your eyes protected from low blue-light emissions.
  • Co paperless with Adobe Scan
    Turn paper documents into digital files using the built-in Adobe Scan, and save your files in a shareable PDF or JPEG format.
Motorola Edge 50 Pro - luxe lavender - 5G smartphone - 512 GB - GSM
5G smartphone
Display
pOLED display - 2712 x 1220 pixels - 6.7" - 446 ppi - (144 Hz) - 20:9 - LTPS - HDR
Qualcomm Snapdragon 7 Gen 3 2.63 GHz
Graphics Accelerator
Qualcomm ADRENO
RAM 12 GB / 512 GB
Operating System
Android 14 with My UX
Main Camera
50 Megapixel - f/1.4 - focus: automatic laser auto focus: - laser focus
Second Camera
13 Megapixel - ultra wide-angle lens - f/2.2
Third Camera
10 Megapixel - telephoto lens - 3x optical zoom - f/2.0
Front Camera
50 Megapixel f/1.9
Service Provider
Not specified
SIM Card
Dual-SIM - nano SIM, Electronic SIM card (e-SIM)
Wireless Interface
Bluetooth, NFC, Wi-Fi 6E, Wi-Fi 6
Security Devices
Fingerprint reader (under display), face recognition
Connectors
USB-C
Protection
Anti-fingerprint coating, water-resistant, dust-resistant
Luxe lavender
72.4 mm x 8.19 mm x 161.23 mm
186 g
0.98 W/kg (head) , 1.34 W/kg (body) , 2.86 W/kg (limb)
Smartphone
Touch
Protection
72.4 mm
8.19 mm
161.23 mm
186 g
Body Colour
Luxe lavender
Body Material
Vegan leather, sandblasted aluminium frame
Cellular
WCDMA (UMTS) / GSM
Mobile Broadband Generation
5G
Service Provider
Not specified
Operating System
Android 14
User Interface
My UX
Intelligent Assistant
Google Assistant
Navigation
GPS, A-GPS, LTEPP, SUPL, GLONASS, Galileo, NavIC
SIM Card Type
Nano SIM, Electronic SIM card (e-SIM)
SIM Card Qty
Dual-SIM
Input Device
Multi-touch
Communications
Data Transmission
LTE, 5G NR FR1
3G UMTS Band
Band 1, Band 2, Band 4, Band 5, Band 8
3G UMTS Frequency
2100, 1900, 1700, 850, 900
4G LTE Band
Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 18, Band 19, Band 20, Band 26, Band 28, Band 32, Band 38, Band 39, Band 40, Band 41, Band 42, Band 43, Band 48, Band 66
4G LTE Frequency
FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 850+, FDD 700 APT, FDD 1500 L, TDD 2600, TDD 1900, TDD 2300, TDD 2500, TDD 3500, TDD 3700, TDD 3600, FDD 1700 - 2110 AWS-3
5G NR Band
N1, n2, n3, n5, n7, n8, n20, n26, n28, n38, n40, n41, n66, n77, n78
5G NR Frequency
FDD 2100, FDD 1900PCS, FDD 1800, FDD 850, FDD 2600, FDD 900, FDD 800, FDD 850, FDD 700APT, TDD TD 2600, TDD 2300, TDD TD 2500, FDD AWS-3, TDD TD 3700, TDD TD 3500
Wireless Interface
Bluetooth 5.4, NFC, Wi-Fi 6E, IEEE 802.11a/b/g/n/ac/ax
Phone Features
Sensors
Proximity sensor, Time of Flight (ToF), accelerometer, gyroscope, SAR sensor, magnetometer
Security Devices
Security Technology
Face Unlock, ThinkShield for Mobile, Moto Secure
Additional Features
RAM Boost, dual stereo speakers, Z-axis linear vibration motor, Dual microphones
Media Player
Sound Enhancements
Dolby Atmos sound technology, Dolby Head Tracking, Snapdragon Sound
Clock Speed
2.63 GHz
Graphics System
Qualcomm ADRENO
RAM
LPDDR4X SDRAM - 12 GB
Internal Memory Capacity
512 GB
Memory Interface
UFS 2.2C
Front Camera
Sensor Resolution
50 Megapixel
Lens Aperture
F/1.9
Pixel Size
0.64 µm
Special Effects
Photo booth, Spot Colour, Live Filters, HDR
Face Detection
Auto smile capture
Camera Modes
Portrait, Pro mode, Capture Dual, Gesture Shot, BurstShot, Timer mode, Assistive Grid
Video Resolutions
1920 x 1080 (1080p) at 30 fps, 1920 x 1080 (1080p) at 60 fps, 3840 x 2160 (4K) at 30 fps
Quad Pixel technology for 1.28 µm, Assistive grid, levelling, RAW photo, Quick Capture
Main Camera
Sensor Resolution
50 Megapixel
Sensor Size
1/1.55"
Optical Image Stabiliser
Optical Image Stabiliser (OIS)
Lens Aperture
F/1.4
Pixel Size
1 µm
Focus Adjustment
Automatic
Laser Auto Focus
Digital Zoom
20x
Self-Timer Delay
Special Effects
Camera Modes
Portrait, Timelapse video, Capture Dual, Ultra-Res, Night Vision, Tilt-shift mode, Pro mode, 360 Panorama mode, Gesture Capture, smart high resolution, BurstShot, metering mode, Watermark mode, Selfie Mirror, Macro mode
Face Detection
Auto smile capture
Light Source
LED flash
Video Resolutions
3840 x 2160 (4K) at 30 fps, 1920 x 1080 (1080p) at 30 fps, 1920 x 1080 (1080p) at 60 fps, Slo-mo video 1920 x 1080 (1080p) at 120 fps, Slo-mo video 1280 x 720 (720p) at 240 fps
Quad Pixel technology for 2.0 µm, Google Lens, shot optimisation, Style Sync, 30x Super Zoom, Assistive Grid, levelling, RAW image capture, QR-code scanner, Barcode Scanner, Quick Capture, Audio zoom, horizon lock
Second Camera
Sensor Resolution
13 Megapixel
Lens Type
Ultra wide-angle lens
Lens Aperture
F/2.2
Field of View (FoV)
120 degree(s)
Pixel Size
1.12 µm
Third Camera
Sensor Resolution
10 Megapixel
Optical Zoom
3x
Lens Type
Telephoto lens
Lens Aperture
F/2.0
Display
pOLED display
LTPS
Diagonal Size
6.7"
Display Resolution
2712 x 1220 pixels
Pixel Density
446 ppi
Aspect Ratio
20:9
Max Brightness
2000 cd/m²
Colour Depth
1.07 billion colours
HDR
HDR Technology
HDR10+
Refresh Rate
144 Hz
Touch Sampling Rate
360 Hz
100% DCI-P3, DC Dimming, 3D Glass
Connector Type
USB Type-C - 24 pin USB-C
4500 mAh
Fast Charging Technology
TurboPower technology
Run Time Details
Mixed usage: up to 40 hrs
Amazon HDR Certification, Netflix HD Certification, SGS Low Blue Light Certification, SGS Low Motion Blur Certification, Pantone Validated, Pantone Skintone Validated, IP68, DisplayPort 1.4, USB 3.1
SIM card removal tool, 125W TurboPower charger, USB-C to USB-C cable, protective case
Max Depth of Water Resistance
1.5 m
Model: Edge 50 Pro
Screen Size: 6.7in
Brand: Motorola
