Set your imagination free with moto e30. The 48MP triple camera system captures images that are sharp and bright in any light. Then, view your photos and videos on a fluid 6.5" 90 Hz Max Vision HD+ display. The 5000 mAh battery powers a custom octa-core processor, to deliver responsive performance.
Brighten your lighting
Sharpen the details in your photos for a more professional look. With the 48MP triple camera system, your shots are clear in any light. -
Bring lighting to life
Take sharp, vibrant photos in any setting or lighting. A 48MP sensor with Quad Pixel technology gives you 4x better low-light sensitivity. -
Turn snapshots into portraits
With a professional look, thanks to the depth sensor, your backgrounds can be customized to enhance different focal points. -
Get closer to your subject
Capture the magic of minute details. Macro Vision brings you 4x closer to your subject. -
Snap stunning selfies
Take your best shots with the 8MP selfie camera. In Face Beauty mode, wrinkles and blemishes are automatically smoothed out. -
Enjoy your view
Experience smooth, fluid visuals and way less lag with a speedy 90 Hz refresh rate. And maximize your viewing on an ultra-wide 6.5" Max Vision HD+ display. -
Feel the power
You have all the speed you need to watch videos, update social feeds, and more with a responsive octa-core processor. -
Your fingerprint is your password
Wake up and unlock your phone by touching the fingerprint reader that doubles as the batwing logo.
- Motorola Moto E30 - mineral grey - 4G smartphone - 32 GB - GSM
- Product Type
- 4G smartphone
- Display
- LCD display - 1600 x 720 pixels - 6.5" - 268 ppi - (90 Hz) - 20:9 - IPS
- Processor
- Unisoc T700 / 1.8 GHz (8-core)
- Graphics Accelerator
- ARM Mali-G52
- Memory
- RAM 2 GB / 32 GB
- Supported Memory Card
- microSDXC slot - up to 1 TB
- Operating System
- Android 11 (Go edition)
- Main Camera
- 48 Megapixel - f/1.79 - focus: automatic
- Second Camera
- 2 Megapixel - f/2.4 - depth camera
- Third Camera
- 2 Megapixel - f/2.4 - macro camera
- Front Camera
- 8 Megapixel f/2.0
- Service Provider
- Not specified
- SIM Card
- Dual-SIM - nano SIM
- Wireless Interface
- Wi-Fi, Bluetooth
- Security Devices
- Fingerprint reader
- Connectors
- 3.5 mm headset jack, USB-C
- Protection
- Splash-resistant
- Mineral grey
- 75.6 mm x 9.1 mm x 165.1 mm
- 198 g
- Specific Absorption Rate (SAR)
- 0.26 W/kg (head) , 1.29 W/kg (body)
- 2-year warranty
- Product Type
- Smartphone
- Form Factor
- Touch
- Protection
- Splash-resistant
- 75.6 mm
- 9.1 mm
- 165.1 mm
- 198 g
- Body Colour
- Mineral grey
- Body Material
- Plastic
- SAR Value
- 1.29 W/kg (body), 0.26 W/kg (head)
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 4G
- Service Provider
- Not specified
- Operating System
- Intelligent Assistant
- Google Assistant
- Navigation
- GPS, A-GPS, GLONASS, Galileo
- SIM Card Type
- Nano SIM
- SIM Card Qty
- Dual-SIM
- Input Device
- Multi-touch
Communications
- Data Transmission
- LTE
- IEEE 802.11a/b/g, Bluetooth 5.0
Phone Features
- Sensors
- Accelerometer, ambient light sensor, proximity sensor
- Security Devices
- Additional Features
- Notification LED, Quick gestures, Google Assistant Key
- Unisoc
- Processor Number
- T700
- Clock Speed
- 1.8 GHz
- Processor Core Qty
- 8-core
Graphics System
- ARM Mali-G52
- RAM
- 2 GB
- Internal Memory Capacity
- 32 GB
- Supported Flash Memory Cards
- microSDHC, microSD, microSDXC - up to 1 TB
Front Camera
- Sensor Resolution
- 8 Megapixel
- Lens Aperture
- F/2.0
- Pixel Size
- 1.12 µm
- Special Effects
- HDR
- Camera Modes
- Pro mode, portrait mode, Face Beauty
- Video Resolutions
- 1920 x 1080 (1080p) at 30 fps, 1280 x 720 (720p) at 30 fps
- Snap in video recording
Main Camera
- Sensor Resolution
- 48 Megapixel
- Lens Aperture
- F/1.79
- Pixel Size
- 0.8 µm
- Focus Adjustment
- Automatic
- Special Effects
- HDR
- Camera Modes
- Panorama, Pro mode, portrait mode, Face Beauty, Night Vision, Macro Vision
- Light Source
- LED flash
- Video Resolutions
- Phase Detect Auto-Focus (PDAF), AI Dual camera, Quad Pixel technology, High-res zoom, 4-in-1 to 1.6µm pixel, Snap in video recording
Second Camera
- Sensor Resolution
- 2 Megapixel
- Lens Aperture
- F/2.4
- Pixel Size
- 1.75 µm
- Functions
- Depth camera
Third Camera
- Sensor Resolution
- 2 Megapixel
- Lens Aperture
- F/2.4
- Pixel Size
- 1.75 µm
- Functions
- Macro camera
Display
- LCD display
- Technology
- IPS
- Diagonal Size
- 6.5"
- Display Resolution
- 1600 x 720 pixels
- Display Format
- HD+
- Pixel Density
- 268 ppi
- Aspect Ratio
- 20:9
- Refresh Rate
- 90 Hz
- Max Vision display
- Connector Type
- USB Type-C - 24 pin USB-C , Headset jack - mini-phone 3.5mm
- Capacity
- 5000 mAh
- Run Time Details
- Standard usage: up to 40 hrs
- IP52
- Included Accessories
- SIM card removal tool, USB-C cable, 10W charger
- Limited warranty - 2 years
