Mophie Powerstation XL - Universal Quick Charge External Battery
Quicklinx: DL6HWS00 Mfr#: 3562_PWRSTION-XL-10K-SGRY
Talk, play and browse longer than ever with the new mophie powerstation XL universal battery. This 10,000mAh universal battery is packed with more power than ever. Get more than three additional charges on your smartphone. Two USB ports let you charge multiple devices.
  • Dual USB charging ports
    With enough battery to recharge a smartphone up to three times, this powerstation battery is also designed for users who need to power multiple devices or simultaneously charge two tablets.
  • Priority+ charging
    Enables pass-through charging while connected to a power source. Your device recharges first, and then the powerstation battery recharges itself.
  • High-output charging
    2.1A output and smart adaptive charging technology identify your connected device and always deliver the fastest, most efficient charging speeds available.
  • Aluminum finish
    High-performance power concealed inside a sophisticated and sleek design make this the perfect accessory for any mobile lifestyle.
mophie powerstation XL power bank - Li-pol - USB
Power bank
6.92 cm x 1.59 cm x 13.2 cm
218 g
Space grey
Output Connector Type
Total 2: USB - on cable: Micro-USB
Max Electric Current
2.1 A
Lithium polymer - 10000 mAh
Cables
Micro-USB cable - 22.9 cm
Power bank
Tablet, mobile phone
6.92 cm
1.59 cm
13.2 cm
218 g
Enclosure Colour
Space grey
Input Connectors
5 pin Micro-USB Type B
Input Connectors Qty
1
Output connectors
Total 2: 4 pin USB Type A
Detachable Cable Connector Type
Micro-USB Type B
2.1 A
Power LED Indicator
Lithium polymer
10000 mAh
Material
Aluminium
FCC, RoHS
