The 6,040mAh charge stream powerstation wireless lets you wirelessly charge your Qi-enabled smartphone anywhere with just the push of a button. You can also charge your wired devices using the high-output 10W USB-A port.
- mophie powerstation wireless power bank - Li-pol - USB - 10 Watt
- Product Type
- Wireless power bank
- 6.9 cm x 12.8 cm x 1.7 cm
- 175 g
- Black
- Output Connector Type
- USB
- Max Electric Current
- 2.1 A
- Wireless Charging
- Wireless Charging Standards
- Qi
- Battery
- Lithium polymer - 6040 mAh
- Power Provided
- 10 Watt
- Power Device Details
- - 4 pin USB Type A - 2.1 A
- 2-year warranty
- Product Type
- 6.9 cm
- 12.8 cm
- 1.7 cm
- 175 g
- Enclosure Colour
- Black
- Input Connectors
- 24 pin USB-C
- Input Connectors Qty
- 1
- Output connectors
- 4 pin USB Type A
- Power Provided
- 10 Watt
- 2.1 A
- Wireless Charging
- Qi
- LED indicator, Priority+ charging
- Technology
- Lithium polymer
- Capacity
- 6040 mAh
- Material
- Thermoplastic polyurethane (TPU)
- Limited warranty - 2 years
