Mophie Powerstation Plus - Universal External Battery
Quicklinx: DL6NWS00 Mfr#: 3461_PSPLUS-6K-2N1-SGRY-BLK
Never carry a charging cable again. The mophie powerstation plus universal battery combines a compact design, premium feel and built-in switch-tip charging cable that charges both Apple and micro USB devices. This 6,000mAh battery gives you more than two additional charges on your smartphone or will keep your tablet charged longer for more reading. A second USB port lets you charge two devices at the same time. Charging on-the-go is now easier than ever.
mophie products go through rigorous testing. Each battery is tested three times to ensure peak performance and safe operation. This is the reason why mophie is the #1 and most trusted brand in portable power.
  • High-output charging
    2.1 A output and smart adaptive charging technology identify your connected device and always deliver fast, efficient charging speeds.
  • Digital power management
    Smart charging circuitry always provides your device with the perfect amount of power for a safe, quick charge.
  • Dynamic power & convenience
    These low-profile universal batteries feature an elegant design and a built-in switch-tip charging cable with micro-USB and Lightning connectors for added convenience.
  • Know before you go
    Push the integrated power indicator button to display the charging status and current battery life of your Powerstation. Know before you go.
mophie Powerstation Plus power bank - USB
Power bank
6.85 cm x 13.37 cm x 1.36 cm
160.2 g
Space grey
Output Connector Type
Total 2: USB - on cable: Micro-USB, Lightning
Max Electric Current
2.1 A
6000 mAh
Cables
Micro-USB cable - 22.9 cm , Lightning to micro-USB adapter
Power bank
Tablet, mobile phone
6.85 cm
13.37 cm
1.36 cm
160.2 g
Enclosure Colour
Space grey
Input Connectors
5 pin Micro-USB Type B
Input Connectors Qty
1
Output connectors
Total 2: 4 pin USB Type A
Detachable Cable Connector Type
Micro-USB Type B, Lightning
2.1 A
LED indicator
6000 mAh
Battery level indicator
