Need even more battery power for your iPhone? The Mophie Juice Pack Plus extends the battery life of your iPhone for hours! The Juice Pack Plus also provides a comfortable ergonomic design with the complete protection of a dual-injected hard shell case with protective rubberized band.
The Juice Pack Plus for iPhone combines rechargeable external battery power concealed inside of a protective form-fitting case. It offers the full protection of a hard-shell case with an ultra-thin, light-weight, low-profile design and shock-resistant band.
Features a simple toggle switch allows for standby and charging mode so you only have to use the Juice Pack Plus battery when you need it! Charge and sync your iPhone to iTunes without removing it from the Juice Pack Plus by using the included USB cable. The integrated LED status indicator on the bottom tells you exactly how much "juice" is left at the push of a button. It also indicates the charging status so you know before you go.
Battery extender and case in one
The Juice Pack Plus for iPhone combines rechargeable external battery power concealed inside of a protective form-fitting case. It offers the full protection of a hard-shell case with an ultra-thin, light-weight, low-profile design and shock-resistant band. -
Standby/charging switch
Features a simple toggle switch allows for standby and charging mode so you only have to use the Juice Pack Plus battery when you need it! -
Charge and sync
Charge and sync your iPhone to iTunes without removing it from the Juice Pack Plus by using the included USB cable. -
Protective rubberized band
The Juice Pack Plus provides a comfortable ergonomic design with the complete protection of a dual-injected hard shell case with protective shock-proof rubberized band. -
Status indicator
The integrated LED status indicator on the bottom tells you exactly how much "juice" is left at the push of a button. It also indicates the charging status so you know before you go. -
Acoustic sound enhancement
The case design acts as a virtual speaker box, redirecting sound from the bottom of the iPhone to the front, resulting in a richer, fuller sound quality.
- mophie Juice Pack Plus external battery pack - Li-pol - Lightning
- Product Type
- External battery pack
- 7.44 cm x 1.68 cm x 15.6 cm
- 111 g
- Black
- Output Connector Type
- Lightning - on cable: Micro-USB
- Battery
- Lithium polymer - 3300 mAh
- Cables
- Micro-USB cable
- 1-year warranty
- Product Type
- Designed For
- Mobile phone
- 7.44 cm
- 1.68 cm
- 15.6 cm
- 111 g
- Enclosure Colour
- Black
- Input Connectors
- 5 pin Micro-USB Type B
- Input Connectors Qty
- 1
- Output connectors
- Apple Lightning
- Detachable Cable Connector Type
- Micro-USB Type B
- Technology
- Lithium polymer
- Capacity
- 3300 mAh
- Max Recharge Cycles
- 500
- Power level indicator button, protective case design, impact-resistant, camera lens cutout, battery level indicator
- Included Accessories
- Headphone adapter
- Cables Included
- Micro-USB cable
- Limited warranty - 1 year
