The juice pack air is a rechargeable external battery concealed inside of a protective form-fitting case for the iPhone 3G and iPhone 3GS. It offers you the full protection of a hard-shell case while providing virtually twice the battery life of the iPhone alone; all in an ultra-thin, light-weight, low-profile design.
Charge and sync
Charge and sync your iPhone to iTunes without removing it from the juice pack air by using the included USB cable. -
Fully protected
The juice pack air not only adds battery life, it is a protective form-fitting case with an ultra-thin, light-weight, low-profile design. -
Status indicator
The integrated LED status indicator tells you exactly how much juice is left at the push of a button. It also indicates the charging status so you know before you go.
- mophie Juice Pack Air external battery pack - Li-pol
- Product Type
- External battery pack
- 6.4 cm x 1.7 cm x 12.9 cm
- 71 g
- Black
- Battery
- Lithium polymer - 1500 mAh
- Cables
- USB cable
- 1-year warranty
- Product Type
- Designed For
- Mobile phone
- 6.4 cm
- 1.7 cm
- 12.9 cm
- 71 g
- Enclosure Colour
- Black
- Technology
- Lithium polymer
- Capacity
- 1500 mAh
- Max Recharge Cycles
- 500
- Overcharge protection, charging status indicator, protective case design
- Cables Included
- USB cable
- Limited warranty - 1 year
