Tempered Glass screen protector with Maximum Clarity + Ultra-smooth Protection. Patented EZ apply tabs make application simple and bubble-free.
Protection that’s engineered to disappear.
- Precisely curved edges fit your screen perfectly for premium edge-to-edge protection.
- High-quality tempered glass delivers maximum image clarity, an ultra-smooth feel and remarkable touch sensitivity.
- With a limited lifetime warranty, if your Glass Contour ever gets worn or damaged, ZAGG will replace it for the life of your device.
- Smart EZ Apply® tabs make applying your Glass Contour simple and accurate.
- ZAGG InvisibleShield Glass Contour - screen protector for mobile phone
- Product Type
- Screen protector
- Intended For
- Mobile phone
- Protection
- Scratch-resistant, impact protection, smudge-proof
- Frame Colour
- White
- Limited lifetime warranty
- Product Type
- Screen protector
- Intended For
- Mobile phone
- Protection
- Frame Colour
- White
- Replacement - lifetime
