Mophie ChargeStream Universal Wireless Pad Mini
Quicklinx: F5H6WS00 Mfr#: 409901505
Compact wireless charging pad. Made for Samsung, Apple, and other Qi-enabled smartphones.
  • Compatible with Qi wireless charging standards
    Designed to work seamlessly with the Qi technology, the charge stream pad mini delivers a safe, reliable 5W charge to virtually any Qi-enabled smartphone. Just place your phone on the non-slip surface and charging begins on contact.
  • Charge through light-weight cases
    The charge stream pad mini can charge through phone cases up to 3 mm thick, so there's no need to pull your case on and off every time you want to charge.
  • Compact and portable design
    The slim charge stream pad mini is the perfect travel buddy. At just 2.4 inches long, it's easy to pack and carry, and it fits easily wherever you want to charge your phone.
  • Safe, worry-free charging
    You can feel secure leaving your phone on the charge stream pad mini. Fail-safe circuitry prevents over-charging and controls temperature to prevent overheating. The low standby current ensures minimal power draw when the pad is idle.
mophie Charge Stream Pad Mini wireless charging mat - 5 Watt
Wireless charging mat
Phone
6 cm x 6 cm x 2 cm
40 g
5 V
Wireless Charging
Wireless Charging Standards
Qi
Power Provided
5 Watt
Cables
Micro-USB to USB cable - 1.5 m
Phone
6 cm
6 cm
2 cm
40 g
Enclosure Colour
5 V
Power Provided
5 Watt
Wireless Charging
Qi
AC Power Adaptor Required
Rubberized, anti-slip surface
