Compact wireless charging pad. Made for Samsung, Apple, and other Qi-enabled smartphones.
Compatible with Qi wireless charging standards
Designed to work seamlessly with the Qi technology, the charge stream pad mini delivers a safe, reliable 5W charge to virtually any Qi-enabled smartphone. Just place your phone on the non-slip surface and charging begins on contact. -
Charge through light-weight cases
The charge stream pad mini can charge through phone cases up to 3 mm thick, so there's no need to pull your case on and off every time you want to charge. -
Compact and portable design
The slim charge stream pad mini is the perfect travel buddy. At just 2.4 inches long, it's easy to pack and carry, and it fits easily wherever you want to charge your phone. -
Safe, worry-free charging
You can feel secure leaving your phone on the charge stream pad mini. Fail-safe circuitry prevents over-charging and controls temperature to prevent overheating. The low standby current ensures minimal power draw when the pad is idle.
- mophie Charge Stream Pad Mini wireless charging mat - 5 Watt
- Product Type
- Wireless charging mat
- Designed For
- Phone
- 6 cm x 6 cm x 2 cm
- 40 g
- Black
- Voltage Required
- 5 V
- Wireless Charging
- Wireless Charging Standards
- Qi
- Power Provided
- 5 Watt
- Cables
- Micro-USB to USB cable - 1.5 m
- 2-year warranty
- Product Type
- Designed For
- Phone
- 6 cm
- 6 cm
- 2 cm
- 40 g
- Enclosure Colour
- Black
- Voltage Required
- 5 V
- Power Provided
- 5 Watt
- Wireless Charging
- Qi
- AC Power Adaptor Required
- Rubberized, anti-slip surface
- Cables Included
- Limited warranty - 2 years
