N-ERGY
High-Performance In-Ear Headphones
Listening is great. Feeling it is better. With Ncredible N-Ergy in-ears you feel the punch of pure Monster Sound. And since they're probably plugged into your smartphone anyway, make and take crystal-clear calls using the in-line mic and controls. And here's twist, snap N- Ergy in-ears together with a magnetic snap and wear them like a neck chain. Now the party goes where you go.
NCREDIBLE STYLE, NCREDIBLE BASS, NCREDIBLE COLORS, NCREDIBLE VALUE!
Put on a pair of N-ERGY in ears and feel your music with the punch of Pure Monster Sound. Take and make crystal-clear calls using in-line mic and controls, best of all, the N-ERGY in-ears come together with a magnetic snap that can be connected around the neck, Now the party goes where you go from Monster. Affordable Luxury at its best!
- Pure Monster Sound
- Super Comfortable
- Snaps Together For Neck Wear Style
- In-Line Controls for Mobile Calls
- Tangle-Free Cables
- Monster NCredible NErgy In-Ear Headphones - earphones
- Product Type
- Earphones - wired - 3.5 mm jack
- Recommended Use
- Portable electronics
- Cherry Red
- Headphones Form Factor
- In-ear
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Noise Isolating
- Noise isolating
- Controls
- Answer/end
- Product Type
- Cherry Red
- Recommended Use
Audio Output
- In-ear
- Wired
- Sound Output Mode
- Stereo
- Noise Isolating
Remote Control
- Controls
- Answer/end
- Connector Type
- Headphones (mini-phone stereo 3.5 mm 4-pole)
- Cable Details
- Headphones cable
