Monster HDMI Ultra High Speed HDMI Cable  - 1 Metre
Quicklinx: 8YTLWS00 Mfr#: 140459-00
Ultimate High Speed Digital Video and Audio Cable for the Sharpest Picture, Deepest Color, and Highest Resolution Sound
Monster's HDMI®1000HD ensures a high definition experience with the maximum audio and visual impact. Movies are just like the director intended and sports and live shows are just like you're there. With a bandwidth of greater than 17.8 Gbps*, no high definition viewing is too demanding, including Blu-ray Disc ™/ HD DVD ™ players and PlayStation® 3 consoles. 1000HD is your connection to the best in HD picture and sound, now and in the future.
Monster Advanced for HDMI® Performance Guarantees:
Monster designs its advanced cables for HDMI to meet and exceed the highest of HDMI standards. If the components you purchase in the future ever surpass the performance of the 1000HD you buy today, Monster will upgrade your cable.
Your Monster Advanced cable for HDMI is covered by the Monsters Live Forever Full Lifetime Warranty® - the best warranty in the business. See packaging for full details.
Monster Advanced for HDMI Performance Capabilities:
8 - 16-Bit Color**
Smoothest Gradation of Colors
Greater cable capacity for support of 16-bit color, also called Deep Color™, available from advanced HD sources and displays. Greater color depth, from 8-bit to 16-bit, allows more detailed gradations of individual colors for the display of billions of colors.
240/480 Hz Display**
Faster Speed for Smooth Motion Video
Ideal for HD components with refresh rates up to 480 Hz yet compatible with slower refresh rates for the smoothest, most fluid video.
Dolby® TrueHD and DTS-HD™
Lossless Surround Sound
Greater cable bandwidth for support of Dolby TrueHD and DTS-HD lossless surround sound, available on Blu-ray Disc™ and HD DVD™ movies.
4K x 2K Resolution
Highest Definition Video
Enables home theater owners with advanced AV sources and displays to achieve the same high resolution picture definition as that of commercial digital cinemas.
Monster 3D
Ready for 3D Displays
Newer 3D movies and games supply two video streams each at 1080p Full HD. With this doubling in bandwidth, the HDMI 1000HD is ready to handle it all with capacity to spare.
V-Grip
For Superior Cable Connections
Many HDMI cables disconnect easily when moved during cleaning or when placed on an articulating mount. The exclusive Monster V-Grip connector increases retention force for a more reliable connection.
Support for HDMI Ethernet Channel: Networked Gear, Fewer Cables
This all-in-one HDMI cable can share your Internet connection with multiple devices. No separate Ethernet cable needed.
Support for Audio Return Channel: Better Sound, Fewer Cables
Transfer uncompressed surround sound from your HDTV with digital tuner to your AV receiver or surround sound controller. No extra audio cable needed.
HDMI is a data superhighway for digital video and audio. For the best highdefinition experience, use an HDMI cable that delivers all the picture and sound data your HD components require. Get all your HDMI questions answered at MonsterCable.com/HDMI.
*Cable data rates measured with jitter under unequalized conditions. Data rates vary over longer lengths.
** Availability of advanced audio/video features is dependent on the capabilities of your components and display.
