The Fastest Monster Advanced® for HDMI Cable Ever
4Kx2K screens provide four times the resolution of 1080p TVs for dazzling displays on par with today's digital cinemas. This quadruples the need for speed. With the bandwidth to handle these higher resolutions on larger displays with faster video frame rates and ever more colors the elite Monster 1200ex delivers the full experience transferring digital video and audio signals at a blazing 15.8 Gbps.
Enjoy Freedom from Obsolescence with Cable for Life Performance Guarantee
Even as advances in AV sources and displays demand ever more bandwidth Monster makes it easy to buy only once and always stay ahead. So if the components you purchase in the future ever surpass the performance of the 1200ex you buy today Monster will upgrade your cable -- with no time limit or expiration date.
Reproduce All the Colours Your Camera and Camcorder can Capture on Your HDTV
Displaying movies and photos on your HDTV in all the living color your camera and camcorder can capture calls for today's higher bandwidth cables like the Monster 1200EX.
Monsters Live Forever Lifetime Warranty
Your Monster Advanced cable for HDMI is covered by the Monsters Live Forever Full Lifetime Warranty -- the best warranty in the business. See packaging for full details.
1200EX for HDMI™ Performance Capabilities
4K x 2K Resolution
Ultra High Definition Video
Enables home theater owners with advanced AV sources and displays to achieve the same high resolution picture definition as that of commercial digital cinemas.
240/480 Hz Display
Faster Speed for Smooth Motion Video**
Ideal for HD components with refresh rates of 480 Hz to 640 Hz yet compatible with slower refresh rates for the smoothest most fluid video.
8 - 16 Bit Color™
Smoothest Gradation of Colors**
Greater cable capacity to handle 16-bit color from advanced HD sources and displays that support this color depth yet compatible with all color depths from 8-bit to 16-bit. Enables more detailed gradations of individual colors for billions of colors realism.
Monster 3D
Ready for 3D Displays
Newer 3D movies and games supply two video streams each at 1080p Full HD. With this doubling in bandwidth the Monster 1200 is ready to handle it all with capacity to spare.
Support for Audio Return Channel: Better Sound Fewer Cables
Transfer uncompressed surround sound from your HDTV with digital tuner to your AV receiver or surround sound controller. No extra audio cable needed.
Support for HDMI Ethernet Channel: Networked Gear Fewer Cables
This all-in-one HDMI cable can share your Internet connection with multiple devices. No separate Ethernet cable needed.
Dolby® TrueHD and DTS-HD™
Lossless Surround Sound
Greater cable bandwidth for support of Dolby TrueHD and DTS-HD lossless surround sound available on Blu-ray Disc™ and HD DVD™ movies.
** Availability of advanced audio/video features is dependent on the capabilities of your components and display.
