Mitsubishi Electric Replacement Lamp for XL5U
Quicklinx: 448WWS00 Mfr#: VLT-XL5LP
Mitsubishi Electric is a recognized leader in the research, engineering, manufacturing and marketing of electrical and electronic equipment used in communications, consumer electronics, industrial technology, energy and transportation.
  • Enhanced brightness
    The Mitsubishi VLT-XL5LP projector lamp is designed to enhance the brightness of your presentations and visuals, ensuring clear and vibrant images even in well-lit rooms.
  • Seamless compatibility
    Specifically engineered for compatibility with PC systems, this projector lamp integrates seamlessly, offering a straightforward setup process and reliable performance.
Mitsubishi VLT-XL5LP - projector lamp
Projector lamp
Mitsubishi XL6U; LVP XL5
Projector lamp
Mitsubishi XL6U , Mitsubishi LVP XL5
