Minute One Protective Sleeve and Screen Cleaner for Laptop 13.3"
Quicklinx: HB5TWS00 Mfr#: SKE-LPS13-MNTO
Device Type: Laptop
Type: Sleeve
Device Screen Size: 13.3
Colour: [N/A]
£20.83 ex VAT
£24.99 inc VAT
Perfect for travel or storage, the padded sleeve is simply designed so your laptop or tablet can easily be accessed. With a top-loading zipper, the laptop case is easy to open, the laptop is easy to open and close and ensures secure containment whether you’re on the road or at home.
The slim design allows you to use it as a stand-alone case or placed in your bag for added portability and protection while you commute. Splash glow is an antibacterial screen cleaner with 15ml of antibacterial fluid and the microfiber cloth attached to one side of the bottle.
Technical specification
Dimensions: 25mm x 2mm
Weight: 300g
Device Type: Laptop
Type: Sleeve
Colour: [N/A]
Brand: Minute One
