Durable protection
The protective cover shields the tablet from scratches and minor impacts while maintaining a sleek appearance. -
Easy functionality
Provides unobstructed access to all ports and buttons, allowing for seamless interaction with the tablet without removing the case. -
Included screen protection
Comes with a Glass Screen Protector to enhance the protection of the tablet's display against everyday hazards.
- Minute One - back cover for tablet
- Product Type
- Back cover for tablet
- Bundled with
- Glass Screen Protector
- Clear
- Designed For
- Apple 10.9-inch iPad (10th generation)
- Package Details
- Hanging box
- Clear
Carrying Case
- Protective cover
- Bundled with
- Recommended Use
- For tablet
- Cover Type
- Back cover
- Designed For
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
HRD3 051046 Condition: Customer return - item has been opened but is in excellent condition |
£4.29 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
