Microsoft Xbox Wireless Headset
Quicklinx: HX52WS00 Mfr#: TLL-00021
Sorry but this product has been discontinued.
View used stock
Game loud and clear with the Xbox Wireless Headset, featuring enhanced auto-mute and voice isolation for crystal-clear chat, intuitive design, plus direct pairing to your console, PC, or phone.
  • Game loud and clear with the Xbox Wireless Headset, featuring enhanced auto-mute and voice isolation for crystal-clear chat, intuitive design, plus direct pairing to your console, PC, or phone
  • Surround yourself with spatial audio technologies including Windows Sonic, Dolby Atmos, and DTS Headphone:X*
  • Dive into sound reimagined. Revealing depth, clarity, and details like never before, Dolby Atmos is a sound experience you can feel all around you.
  • Enjoy up to 20 hours of battery life with the internal, rechargeable battery
  • Be heard clearly with enhanced auto-mute and voice isolation that reduce background noise for crystal-clear chat
  • Experience the flexible, lightweight design with an adjustable headband that provides a more comfortable experience during extended play sessions
  • Rotate the earcup dials for a quick, intuitive way to adjust volume and game/chat balance
  • Fine-tune your headset with the Xbox Accessories app for a customized audio experience*
  • Pair directly to your console with Xbox Wireless radio without the need for dongles or a base station
  • Connect to your PC or mobile device with Bluetooth® for on-the-go music or chat – even pair to your phone and Xbox simultaneously to chat with a friend on your phone while playing on your console
*See xbox.com/headset-compatibility. Audio customization available via the Xbox Accessories app for Xbox Series X|S, Xbox One, and Windows 10/11 devices. Dolby Atmos and DTS:X: may require additional purchases, app downloads, and supported hardware. Battery life varies significantly with distance from console, additional accessories, usage and other factors. Testing conducted by Microsoft using pre-production units.
  • Advanced audio technology
    Utilizes DTS Headphone:X and Dolby Atmos to deliver an audio experience, enhancing gameplay with spatial sound.
  • Comfortable design
    Full-size headphones with soft foam and polyurethane leather earpads provide hours of comfortable use during gaming sessions.
  • Seamless connectivity
    Equipped with Bluetooth 5.3 for quick and reliable wireless connections to gaming consoles and computers.
  • Versatile controls
    Features easy-to-use controls for mute, volume, and game/chat balance, allowing players to manage audio effortlessly.
  • Long battery life
    The rechargeable lithium-ion battery offers extended playtime, ensuring the headset is ready for gaming marathons.
Microsoft Xbox Wireless Headset - headset
Headset - Bluetooth - wireless
Compatibility
Windows, Xbox One, Xbox Series S, Xbox Series X
Recommended Use
Game console, computer
Gaming
Style
Games
Headphones Form Factor
Full size
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.3
Sound Output Mode
Stereo
Sound Effects
Windows Sonic spatial sound, DTS Headphone:X
Audio Specifications
Frequency Response 20 - 20000 Hz
Impedance
32 Ohm
Diaphragm Type
Paper composite
Microphone
Boom
Controls
Power on/off, pair mode, mute, game/chat balance, volume
Xbox One, Series S, Series X
Compatibility
Style
Games
320 g
Headband Material
Foam, metal
Earpad Material
Polyurethane leather, foam
Recommended Use
Gaming
Bendable microphone arm, LED indicator
Audio Output
Full size
Wireless
Wireless Technology
Bluetooth
Bluetooth Audio Codec
SBC
Bluetooth Version
Bluetooth 5.3
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP), Hands-Free Profile (HFP), Headset Profile (HSP)
Sound Output Mode
Stereo
Built-in Decoders
Dolby Atmos
Sound Effects
Frequency Response
20 - 20000 Hz
Impedance
32 Ohm
Diaphragm
Paper composite - 40 mm
Magnet Material
Neodymium
Microphone
Boom
Headset microphone
Remote Control
Controls
Connector Type
USB-C (power only) (24 pin USB-C)
Supported Host Device OS
Windows 10, Windows 11
Headset battery rechargeable - Lithium Ion
Run Time (Up To)
20 hour(s)
Run Time Details
Continuous playback (with 30 min charge): up to 4 hours
Recharge Time
3 hour(s)
Microsoft Xbox One, Series S, Series X
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: HX52 051377
Condition: Customer return - item has been used and shows signs of use
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not present or functional  This part of the stock item is not present or functional  £54.84
Ref: HX52 051396
Condition: Customer return - item has been repaired under warranty by the manufacturer Please note: The box is damaged however the product is in perfect condition.
This part of the stock item is present and in good condition  This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £64.47
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Brand: Microsoft
Stock Status: Used Stock
Stock Status: Clearance
