Experience the modernised design of the Xbox Wireless Controller in Velocity Green, featuring sculpted surfaces and refined geometry for enhanced comfort during gameplay. Stay on target with a hybrid D-pad and textured grip on the triggers, bumpers, and back-case. Seamlessly capture and share content such as screenshots, recordings, and more with the Share button. Connect using the USB-C port for direct plug and play to console and PC. Support for AA batteries is included on the rear. Get up to 40 hours of battery life. Plug in any compatible headset with the 3.5mm audio jack. Use the Xbox Accessories app to remap buttons and create custom controller profiles for your favourite games. Quickly pair with, play on, and switch between devices including console, PC, and mobile.*
Custom mapping
Make the controller your own by customising button mapping with the Xbox Accessories app.* Plus, plug in any compatible headset with the 3.5mm audio headset jack.
Xbox Wireless and Bluetooth® technology
Includes Xbox Wireless and Bluetooth technology for wireless gaming on console, PC, mobile phones, and tablets.*
Stay on target
Stay on target with a hybrid D-pad and textured grip on the triggers, bumpers, and back-case. Connect using the USB-C port for direct plug and play to console and PC. Support for AA batteries is included on the rear.
Share button
Easily pair and switch
Quickly pair with, play on, and switch between devices including?console, PC, and mobile.*
*Important information: Compatible with select devices and operating system versions; learn more at xbox.com/controller-compatibility. Battery life varies significantly with headsets, additional accessories, usage, and other factors. Testing conducted by Microsoft using standard AA batteries in preproduction units. Button mapping available via Xbox Accessories app for Xbox Series X|S, Xbox One, and Windows 10/11; app for Windows 10/11 requires compatible USB-C cable (sold separately or included with Xbox Elite Wireless Controller – Series 2).
Windows 10/11: Requires Bluetooth, compatible USB-C cable, or Xbox Wireless adapter. Each sold separately. Android, iOS, and Bluetooth: Select devices and versions. Some functionality not supported. Software download may be required via Windows PC or console. See xbox.com/controller-compatibility. Use with controller compatible games. You must accept the Warranty & Agreement at xbox.com/warranty and Software License Agreement at xbox.com/slt.
- Microsoft Xbox Wireless Controller - gamepad - wireless - Bluetooth
- Product Type
- Gamepad
- Connectivity Technology
- Wireless - Bluetooth
- Controls
- D-pad, 2 Thumb Sticks, Triggers, Share Button
- Xbox Wireless Support, Textured Grip
- Velocity Green
- Designed For
- Xbox Series X and S, PC Android
