Microsoft Xbox Wireless Controller - Electric Volt
Quicklinx: G9QMWS00 Mfr#: QAU-00022
Colours:
Experience the incredible intensity, precision and comfort of the Xbox Wireless Controller. Impulse triggers deliver fingertip vibration feedback, so you can feel every jolt and crash in high definition. Responsive thumbsticks and an enhanced D-pad provide greater accuracy.
Compatible with select devices and operating system versions; learn more at xbox.com/controller-compatibility. Battery life varies significantly with headsets, additional accessories, usage, and other factors. Testing conducted by Microsoft using standard AA batteries in preproduction units. Button mapping available via Xbox Accessories app for Xbox Series X|S, Xbox One, and Windows 10/11; app for Windows requires compatible USB-C cable (sold separately).
Windows 10/11: Requires Bluetooth, compatible USB-C® cable, or Xbox Wireless adapter. Each sold separately. Android, iOS, & Bluetooth: Select devices and versions. Some functionality not supported. Software download may be required via Windows PC or console. See xbox.com/controller-compatibility. Use with controller compatible games. You must accept the Warranty & Agreement at xbox.com/warranty and Software License Agreement at xbox.com/slt.
Microsoft Xbox Wireless Controller - gamepad - wireless - Bluetooth
Gamepad
Wireless - Bluetooth
Controls
D-pad, 2 thumb sticks, triggers, Share button
Textured grip, Xbox Wireless support, headset port
Electric volt
PC, Microsoft Xbox One, Android, Microsoft Xbox Series S, Microsoft Xbox Series X, iOS
Gamepad
Controls
Electric volt
Windows 10, Android, Apple iOS
Required Battery
AA type
