Vaporize your competition with the Xbox Wireless Controller – Stormcloud Vapor featuring a dynamic blue color swirl that’s unique to every controller. Play on console, PC, and mobile. Harness the power of storming skies in your hands with the uniquely created color swirl—each with its own energy and pattern. Hold on to the action with rubberized, blue diamond-pattern grips on the back-case. Stay on target with a hybrid D-pad and textured grip on the triggers, bumpers, and side caps. Seamlessly capture and share content such as screenshots, recordings, and more with the dedicated Share button. Connect using the USB-C® port for direct plug and play to console and PC. Support for AA batteries is included on the rear. Get up to 40 hours of battery life. Plug in any compatible headset with the 3.5mm audio jack. Use the Xbox Accessories app to remap buttons and create custom controller profiles for your favorite games. Quickly pair with, play on, and switch between devices including console, PC, and mobile.*
Stay on target with the hybrid D-pad and textured grip on the triggers, bumpers, and side caps. Plug in any compatible headset with the 3.5mm audio headset jack.
Includes Xbox Wireless and Bluetooth® technology for wireless gaming on supported consoles, Windows PCs, and Android and iOS phones and tablets.*
