Microsoft Wireless Mobile Mouse 3600 - Red
Quicklinx: BQQTWS00 Mfr#: PN7-00013
Wired / Wireless: Wireless
Colour: Dark red
Compatibility: Android, Mac, PC
£20.14 ex VAT
£24.16 inc VAT
You'll appreciate how the Bluetooth Mobile Mouse 3600 comfortably fits your hand and your mobile lifestyle. Use it just about anywhere, even on a rough park bench or your living room carpet, relying on Microsoft BlueTrack Technology. No transceivers or wires to manage. Keep using your mouse for up to six months with a single battery.
  • Compact design for ultimate portability
    Its compact design makes it ideal for travel.
  • 4-way scroll wheel
    4-way scroll wheel for navigating up, down, left and right
  • BlueTrack technology
    Take advantage of BlueTrack Technology, which combines the power of optical with the precision of laser for remarkable tracking on virtually any surface. Take advantage of BlueTrack Technology, which combines the power of optical with the precision of laser for remarkable tracking on virtually any surface.BlueTrack Technology does not work on clear glass or mirrored surfaces.
  • Comfortable in either hand
    Use your mouse with your left or right hand. Ambidextrous design makes it comfortable either way.
  • Bluetooth smart
    Clutter-free and reliable experience utilizing the latest in Bluetooth 4.0 technology.
  • Up to 6-month battery life
    Use your mouse for up to six months without having to change batteries.
Microsoft Bluetooth Mobile Mouse 3600 - mouse - Bluetooth 4.0 - dark red
Mouse
Wireless - Bluetooth 4.0
Dark red
Orientation
Right and left-handed
5.69 cm x 9.53 cm x 4.04 cm
63 g
Movement Detection Technology
Optical
Buttons Qty
3
Movement Resolution
1000 dpi
Performance
Up to 30 inches per second, 4000 fps, 10 G maximum acceleration
Scrolling 4-way button, Microsoft BlueTrack Technology
AA type
Android 5.0 (Lollipop), Apple MacOS X 10.10, Windows 8 / 8.1 / 10 (32/64 bits)
3-year warranty
Mouse
Orientation
5.69 cm
9.53 cm
4.04 cm
63 g
Dark red
Input Device
Wireless
Bluetooth 4.0
Max Operating Distance
Up to 10 m
Optical
Buttons Qty
3
Movement Resolution
1000 dpi
Performance
VCCI, BSMI, ISO 9001, ICES-003, ISO 14001, MIC, MOC, FCC, NTRA, WEEE, ANATEL, TELEC, URSEC, China EIP, Nordic Ecolabel, CITC, RATEL, NCC, iDA, MSIP, ICASA, TRA, ICT
AA type
Alkaline
Run Time (Up To)
1 year
Limited warranty - 3 years
5 - 80% (non-condensing)
Colour: Dark red
Compatibility: Mac
Compatibility: PC
Brand: Microsoft
Price Range Ex VAT: 0 - 50
