You'll appreciate how the Bluetooth Mobile Mouse 3600 comfortably fits your hand and your mobile lifestyle. Use it just about anywhere, even on a rough park bench or your living room carpet, relying on Microsoft BlueTrack Technology. No transceivers or wires to manage. Keep using your mouse for up to six months with a single battery.
Compact design for ultimate portability
Its compact design makes it ideal for travel. -
4-way scroll wheel
4-way scroll wheel for navigating up, down, left and right -
BlueTrack technology
Take advantage of BlueTrack Technology, which combines the power of optical with the precision of laser for remarkable tracking on virtually any surface. Take advantage of BlueTrack Technology, which combines the power of optical with the precision of laser for remarkable tracking on virtually any surface.BlueTrack Technology does not work on clear glass or mirrored surfaces. -
Comfortable in either hand
Use your mouse with your left or right hand. Ambidextrous design makes it comfortable either way. -
Bluetooth smart
Clutter-free and reliable experience utilizing the latest in Bluetooth 4.0 technology. -
Up to 6-month battery life
Use your mouse for up to six months without having to change batteries.
- Microsoft Bluetooth Mobile Mouse 3600 - mouse - Bluetooth 4.0 - dark red
- Mouse
- Connectivity Technology
- Wireless - Bluetooth 4.0
- Dark red
- Orientation
- Right and left-handed
- 5.69 cm x 9.53 cm x 4.04 cm
- 63 g
- Movement Detection Technology
- Optical
- Buttons Qty
- 3
- Movement Resolution
- 1000 dpi
- Performance
- Up to 30 inches per second, 10 G maximum acceleration, 4000 fps
- Scrolling 4-way button, Microsoft BlueTrack Technology
- Battery
- AA type
- OS Required
- Windows 8 / 8.1 / 10 (32/64 bits), Apple MacOS X 10.10, Android 5.0 (Lollipop)
- 3-year warranty
- Mouse
- Orientation
- 5.69 cm
- 9.53 cm
- 4.04 cm
- 63 g
- Dark red
Input Device
- Wireless
- Interface
- Bluetooth 4.0
- Max Operating Distance
- Up to 10 m
- Optical
- Buttons Qty
- 3
- 1000 dpi
- Performance
- VCCI, BSMI, ISO 9001, ICES-003, ISO 14001, MIC, MOC, FCC, NTRA, WEEE, ANATEL, TELEC, URSEC, China EIP, Nordic Ecolabel, CITC, RATEL, NCC, iDA, MSIP, ICASA, TRA, ICT
- AA type
- Technology
- Alkaline
- Run Time (Up To)
- 1 year
- OS Required
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 5 - 80% (non-condensing)
