Brand
Microsoft Wireless Mobile Mouse 3500 - Pink
Quicklinx: 8DN9WS00 Mfr#: GMF-00276
Type: Mouse
Wired / Wireless: Wireless
Colour: Magenta
Compatibility: PC
Colours:
£17.29 ex VAT
£20.74 inc VAT
Keep moving with a transceiver that stays in your mobile PC when you go and a mouse that works on more surfaces with Microsoft BlueTrack technology!
  • BlueTrack technology
    Microsoft BlueTrack technology combines the power of optical with the precision of laser for remarkable tracking on virtually any surface.
  • Plug-and-go nano transceiver
    Leave the Nano Transceiver plugged in when you're on the go, or stow it in the mouse.
  • On/off switch
    Conserve more battery power by turning your mouse off when not in use.
  • Comfortable in either hand
    Use your mouse with your left or right hand - ambidextrous design makes it comfortable either way.
Microsoft Wireless Mobile Mouse 3500 - mouse - 2.4 GHz - magenta
Mouse
Wireless - 2.4 GHz
Magenta
Orientation
Right and left-handed
5.7 cm x 9.5 cm x 4 cm
90 g
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Optical
Buttons Qty
3
Movement Resolution
1000 dpi
Performance
8000 fps
Scrolling wheel, rubber side grips, battery indicator, on/off power switch, Microsoft BlueTrack Technology
1 x AA type
Microsoft Windows 7, Windows 8, Windows 8.1, Windows RT
Microsoft Certification
Compatible with Windows 7
3-year warranty
Mouse
Wireless Receiver
Orientation
5.7 cm
9.5 cm
4 cm
90 g
Magenta
Input Device
Wireless
2.4 GHz
Max Operating Distance
Up to 10 m
Optical
Buttons Qty
3
Movement Resolution
1000 dpi
Performance
8000 fps
1 x USB - 4 pin USB Type A
Plug and Play; USB 2.0
AA type
Alkaline
Installed Qty
1
Run Time (Up To)
8 months
Limited warranty - 3 years
5 - 80% (non-condensing)
Type: Mouse
Colour: Magenta
Compatibility: PC
Brand: Microsoft
Stock Status: In stock
