Keep moving with a transceiver that stays in your mobile PC when you go and a mouse that works on more surfaces with Microsoft BlueTrack technology!
Microsoft BlueTrack technology combines the power of optical with the precision of laser for remarkable tracking on virtually any surface. -
Plug-and-go nano transceiver
Leave the Nano Transceiver plugged in when you're on the go, or stow it in the mouse. -
On/off switch
Conserve more battery power by turning your mouse off when not in use. -
Comfortable in either hand
Use your mouse with your left or right hand - ambidextrous design makes it comfortable either way.
- Microsoft Wireless Mobile Mouse 3500 - mouse - 2.4 GHz - magenta
- Mouse
- Connectivity Technology
- Wireless - 2.4 GHz
- Magenta
- Orientation
- Right and left-handed
- 5.7 cm x 9.5 cm x 4 cm
- 90 g
- Wireless Receiver
- USB wireless receiver
- Movement Detection Technology
- Optical
- Buttons Qty
- 3
- Movement Resolution
- 1000 dpi
- Performance
- 8000 fps
- Scrolling wheel, rubber side grips, battery indicator, on/off power switch, Microsoft BlueTrack Technology
- Battery
- 1 x AA type
- OS Required
- Microsoft Windows 7, Windows 8, Windows 8.1, Windows RT
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty
- Mouse
- Wireless Receiver
- Orientation
- 5.7 cm
- 9.5 cm
- 4 cm
- 90 g
- Magenta
Input Device
- Wireless
- Interface
- 2.4 GHz
- Max Operating Distance
- Up to 10 m
- Optical
- Buttons Qty
- 3
- 1000 dpi
- Performance
- 8000 fps
- 1 x USB - 4 pin USB Type A
- Plug and Play; USB 2.0
- AA type
- Technology
- Alkaline
- Installed Qty
- 1
- Run Time (Up To)
- 8 months
- OS Required
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 5 - 80% (non-condensing)
