Product
Microsoft Wireless Desktop 900 - Keyboard and Mouse Set - UK layout
AES Technology for maximum security!
Quicklinx: BQQYWS00 Mfr#: PT3-00006
Recommended Use: Office
Type: Mouse
Wired / Wireless: Wireless
Colour: Black
Compatibility: Mac, PC
More than 50 in stock
£27.71 ex VAT
£33.25 inc VAT
This sleek desktop is contemporary and minimalistic. It has quiet-touch keys for a serene typing experience and a full-size mouse that provides comfortable, precise navigation. The Wireless Desktop 900 also includes Advanced Encryption Standard (AES), which is designed to help protect your information by encrypting your keystrokes. Both the keyboard and the mouse have an average battery life of 2-years and provide easy access to commonly used Windows features to keep you productive and efficient.
Advanced Encryption Standard (AES) 128-Bit Encryption
This keyboard features Advanced Encryption Standard (AES*) technology, which is designed to help protect your information by encrypting your keystrokes. Each keyboard is permanently paired with its receiver at the factory—no key information is ever shared over the air.
Quiet-touch keys
Quiet-touch keys provide comfortable, responsive typing.
Easy, reliable plug-and-play transceiver
Transceiver lets you set up in seconds and offers a reliable connection with a wireless range of up to 30-feet.
Easy-Access Hot Keys
Quickly access frequently used tools, like the calculator and audio controls by using shortcut keys.
Full-size mouse
Larger mouse size is designed for greater comfort and more precise navigation.
2-year average battery life
Low power consumption provides 2-year average battery life for both the keyboard and mouse based on normal usage.
  • Advanced Encryption Standard (AES) 128-bit encryption
    This keyboard features Advanced Encryption Standard (AES) technology, which is designed to help protect your information by encrypting your keystrokes. Each keyboard is permanently paired with its receiver at the factory - no key information is ever shared over the air.
  • Quiet-touch keys
  • Easy, reliable plug-and-play transceiver
  • Easy-access hot keys
    Provide easy access to commonly used functions.
  • Full-size mouse
Microsoft Wireless Desktop 900 - keyboard and mouse set - UK
Keyboard and mouse set - wireless
2.4 GHz
Wireless Receiver
USB wireless receiver
Input Device
Keyboard
Layout
Keys Qty
105
Numeric Keypad
Pointing Device
Mouse - wireless - optical
3 years warranty
2.4 GHz
Max Operating Distance
Up to 9.1 m
Wireless Receiver
Dimensions (WxDxH) / Weight
Keyboard: 42.4 cm x 15.5 cm x 2.82 cm / 517 g , Mouse: 6.31 cm x 11.3 cm x 4.41 cm / 72.5 g , Wireless receiver: 2.76 cm x 1.5 cm x 0.689 cm / 2.8 g
Input Device
Keyboard
Keys Qty
105
Layout
Numeric keypad
Pointing Device
Mouse
Pointing Device Name
Microsoft Wireless Mouse 900 - wireless
Movement Detection Technology
Optical
Included Software
Drivers & Utilities
Microsoft Windows 7, Apple MacOS X 10.4 - 10.7, Windows 8, Windows 8.1, Windows 10
AAA type
Installed Qty
2
Alkaline
Limited warranty - 3 years
5 - 80% (non-condensing)
Type: Mouse
Colour: Black
Compatibility: Mac
Compatibility: PC
Brand: Microsoft
Price Range Ex VAT: 0 - 50
