Secured connection, reliable performance Control and convenience are at your fingertips with this compact keyboard and reliable mouse. The strong and secured wireless signal allows you to choose where you want to work. And the desktop is easy to use--just load batteries, plug in the transceiver, and start typing.
Mouse Features
Microsoft® Optical Technology 1000 dpi provides responsive cursor control.
Snap-in Transceiver Stows conveniently under mouse for portability. Power switch turns the mouse on and off for up to 8 months of battery life.
Designed for Comfort Comfortable in left or right hand.
Scroll Wheel For faster on-screen navigation.
Power Switch Turns the mouse on and off.
Longer Battery Life Up to 8 months of battery life.
Ketboard Features
Easy-Access Hot Keys Quickly access Calculator, volume controls, mute, and play/pause.
Windows Start Button Simply press to launch your Start menu. If you have Windows Vista installed, search your PC or the Web right from there.
Longer Battery Life Up to 15 months of battery life.
Requires a PC that meets the requirements for and has installed one of these operating systems: Windows® 7, Windows Vista®, Windows XP.
USB only
2 AAA and 2 AA alkaline batteries (included)
Dimensions: L 508mm x W 130.6mm
Secured wireless connection
Microsoft 2.4 GHz wireless delivers a secured and reliable connection with up to 15-foot range. -
Battery status indicators
Lights let you know when your batteries are running low.
- Microsoft Wireless Desktop 800 - keyboard and mouse set - UK - black Input Device
- Keyboard and mouse set
- Interface
- 2.4 GHz
- Wireless Receiver
- USB wireless receiver
- Connectivity Technology
- Wireless
- Localization and Layout
- UK
- Pointing Device
- Mouse - optical
- 1000 dpi resolution
- Black
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty
- Interface
- 2.4 GHz
- Wireless Receiver
- Wireless
- UK
Pointing Device
- Mouse
- Movement Detection Technology
- Optical
- Pointing Device Features
- Black
- OS Required
- Apple MacOS X 10.2, Microsoft Windows Vista / XP / 7
- Limited warranty - 3 years
