Microsoft Wireless Desktop 800 for Business
Quicklinx: 7CX7WS00 Mfr#: 5SH-00005
Secured connection, reliable performance control and convenience are at your fingertips with this compact keyboard and reliable mouse. The strong and secured wireless signal allows you to choose where you want to work. And the desktop is easy to use - just load batteries, plug in the transceiver, and start typing.
  • Secured wireless connection
    Microsoft 2.4GHz wireless delivers a secured and reliable connection with up to 15-foot range.
  • Easy-access hot keys
    Quickly access calculator, volume controls, mute, and play/pause.
  • Microsoft optical technology
    1000dpi provides responsive cursor control.
  • Snap-in transceiver
    Stows conveniently under mouse for portability. Power switch turns the mouse on and off for up to 8 months of battery life.
Microsoft Wireless Desktop 800 for Business - keyboard and mouse set - UK - black Input Device
Keyboard and mouse set
2.4 GHz
Wireless Receiver
USB wireless receiver
Wireless
Localization and Layout
Hot Keys Function
Calculator, volume, mute
Pointing Device
Mouse - optical
Scrolling wheel, on/off power switch, 1000 dpi resolution, right and left-handed
Microsoft Certification
Compatible with Windows 7
2.4 GHz
Wireless Receiver
Wireless
Hot Keys Function
Pointing Device
Mouse
Movement Detection Technology
Optical
Pointing Device Features
Apple MacOS X 10.4.x - 10.6.x, Microsoft Windows Vista / XP / 7
