Brand
Microsoft Wireless Desktop 3050
AES TECHNOLOGY FOR MAXIMUM SECURITY!
Quicklinx: BQQZWS00 Mfr#: PP3-00006
Wired / Wireless: Wireless
Compatibility: PC
£33.29 ex VAT
£39.94 inc VAT
Upgrade your laptop or desktop computer experience with this wireless keyboard and mouse set that packs an abundance of convenient features into modern design. The keyboard's soft-touch palm rest and quiet keys lend an elegantly professional look and feel that you'll enjoy day after day. And, the keyboard has function to match its form - enjoy the convenience of media playback controls, one-touch zoom, and customizable keyboard shortcut keys that access programs in the Windows Taskbar. This keyboard also features Advanced Encryption Standard (AES) technology, which is designed to help protect your information by encrypting your keystrokes. Microsoft BlueTrack Technology in the mouse gives you precise control on virtually any surface, while the rubber side grips and slightly longer mouse body provide an amazingly comfortable feel1. Plus, you can wander up to 30 feet away from your PC and maintain a dependable wireless connection.
  • Advanced Encryption Standard (AES) 128-bit encryption
    This keyboard features Advanced Encryption Standard (AES) technology, which is designed to help protect your information by encrypting your keystrokes. Each keyboard is permanently paired with its receiver at the factory - no key information is ever shared over the air.
  • Built in palm rest
    Built in palm rest helps support and straighten wrists
  • Wireless freedom and convenience
    Give yourself room to move with a wireless keyboard that lets you work without worrying about tangled wires, using a USB transceiver.
  • Customizable shortcut keys
    Customizable Windows shortcut keys to easily access your favorite programs1
  • BlueTrack technology
    Take advantage of BlueTrack Technology, which combines the power of optical with the precision of laser for remarkable tracking on virtually any surface.
Microsoft Wireless Desktop 3050 - keyboard and mouse set - UK
Keyboard and mouse set
2.4 GHz
Wireless Receiver
USB wireless receiver
Wireless
Localization and Layout
Keys Qty
105
Hot Keys Function
My Pictures, my Documents, calculator, e-mail, volume, mute, My Favourite, Skype, play/pause, previous track, next track, home page, music
Pointing Device
Mouse - wireless - optical
Buttons Qty
5
3-year warranty
2.4 GHz
Wireless Receiver
Dimensions (WxDxH) / Weight
Keyboard: 46.7 cm x 19.9 cm x 4.43 cm / 829 g , Mouse: 7.025 cm x 11.67 cm x 4.22 cm / 152 g , Wireless receiver: 4.654 cm x 1.575 cm x 0.785 cm / 5 g
Input Device
Wireless
Keyboard Name
Microsoft Wireless Keyboard 3050
Keys Qty
105
Hot Keys Function
Palm Rest
Pointing Device
Mouse - wireless
Pointing Device Name
Microsoft Wireless Mouse 5000
Buttons Qty
5
Movement Detection Technology
Optical
Included Software
Drivers & Utilities
Microsoft Windows 7, Windows 8, Windows 10
AA type
Installed Qty
2
Alkaline
Limited warranty - 3 years
5 - 80% (non-condensing)
Compatibility: PC
Brand: Microsoft
