Brand
Microsoft Wireless Desktop 2000 AES
AES TECHNOLOGY FOR MAXIMUM SECURITY!
Customer rating: 4.0* (Write a review)
Quicklinx: 7VK3WS00 Mfr#: M7J-00020
Recommended Use: Leisure, Office
Type: Keyboard
Wired / Wireless: Wireless
Colour: Black
Compatibility: PC, Mac
£25.07 ex VAT
£30.08 inc VAT
Unlike standard keyboards, this one features Advanced Encryption Standard (AES), which can help protect your personal and business information by encrypting what you type. Enjoy the classically designed keyboard, with a pillow-textured palm rest for support and comfort. The desktop is completed with a wireless, full-size mouse that features enhanced side grips, four-way scrolling and Blue Track technology. Not only is this desktop secures, comfortable and convenient - it's simple to use - just plug in the transceivers and you're ready to go!
  • Advanced Encryption Standard (AES) 128-bit encryption
    The Wireless Keyboard 2000 features Advanced Encryption Standard (AES), which can help protect your personal and business information by encrypting what you type.
  • Windows start button
    Press to launch your Start menu and search your PC or the web if you have Windows Vista or later installed.
  • Pillow-texture palm rest
    The pillow-textured palm rest gives comfortable support while you type.
  • Comfort and control for either hand
    Experience full-size comfort with enhanced side grips for control, a shape that fits both hand, and a tilt wheel for easy side-to-side scrolling.
  • BlueTrack technology
    It works on virtually any surface in your home, office, or anywhere in between.
  • Battery status indicator
    Be aware of your battery power, at a single glance.
  • Wireless freedom and convenience
    Give yourself room to move with a wireless keyboard that lets you work without worrying about tangled wires, using a USB transceiver.
Header / Product Line
Keyboard & Mouse
Wired / Wireless
Wireless
Compatibility
PC
Pack Size
1
Customer reviews
Write a review for the Microsoft Wireless Desktop 2000 AES here!
microsft mouse and keyboard
Reviewed by Mark O'Farrell. Review Posted 23/12/2020
easy to use system and support
  • Overall 4*
  • Ease of use 4*
  • Value for money 4*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
Recommended Use: Office
Type: Keyboard
Colour: Black
Compatibility: PC
Compatibility: Mac
Brand: Microsoft
