Microsoft Wireless Comfort Desktop 5050
AES TECHNOLOGY FOR MAXIMUM SECURITY!
Quicklinx: BQR0WS00 Mfr#: PP4-00006
Wired / Wireless: Wireless
Compatibility: Android, Mac, PC
Stock Status: In Stock, Used Stock
£41.66 ex VAT
£49.99 inc VAT
Give yourself the freedom to move around with a wireless keyboard that lets you work without worrying about tangled wires.
Microsoft Wireless Comfort Desktop 5050 - keyboard and mouse set - UK
Keyboard and mouse set - ergonomic
2.4 GHz
Wireless Receiver
USB wireless receiver
Input Device
Keyboard
Wireless
Localization and Layout
Keys Qty
105
Hot Keys Function
My Pictures, my Documents, calculator, e-mail, volume, mute, My Favourite, Skype, play/pause, previous track, next track, home page, music
Pointing Device
Mouse - wireless - optical
Buttons Qty
5
3-year warranty
2.4 GHz
Wireless Receiver
Dimensions (WxDxH) / Weight
Keyboard: 46.9 cm x 21.8 cm x 3.73 cm / 829 g , Mouse: 7.025 cm x 11.67 cm x 4.22 cm / 152 g , Wireless receiver: 4.654 cm x 1.575 cm x 0.785 cm / 5 g
Input Device
Keyboard - wireless
Keyboard Name
Microsoft Wireless Comfort Keyboard 5050
Keys Qty
105
Hot Keys Function
Palm Rest
Pointing Device
Mouse - wireless
Pointing Device Name
Microsoft Wireless Mouse 5000
Buttons Qty
5
Movement Detection Technology
Optical
AES-128
Included Software
Drivers & Utilities
Microsoft Windows 7, Android 3.2 (Honeycomb) or later, Microsoft Windows RT 8.1, Microsoft Windows RT 8, Windows 8 / 8.1, Windows 10, Apple MacOS X 10.7.x - 10.10.x
AA type
Installed Qty
2
Alkaline
Limited warranty - 3 years
5 - 80% (non-condensing)
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: BQR0 042551
Condition: Customer return - item shows signs of use
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £37.06
Ref: BQR0 042431
Condition: Customer return - item has been used but is in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £30.47
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Compatibility: Mac
Compatibility: PC
Brand: Microsoft
Stock Status: Used Stock
Price Range Ex VAT: 0 - 50
