Microsoft Wired Keyboard 600 White
Quicklinx: 5GCRWS00 Mfr#: ANB-00026
This keyboard combines a spill-resistant keyboard with all the features you need - and more - with Microsoft quality and reliability. Enjoy plug-and-play setup and quiet touch keys with quick access to media controls and calculator.
  • Media center
    Four hot keys let you control the most-used media activities (play/pause, volume up, volume down, and mute).
  • Calculator hot key
    With the touch of the button, you can quickly access the calculator.
  • Spill-resistant design
    Enjoy a drink while you work - this keyboard is designed to withstand an accidental spill.
  • Plug and Play
    No software needed. Just connect the keyboard to your PC and go!
  • Device stage
    Quickly and easily access common tasks, including product information, registration, settings and more for popular devices such as cell phones, cameras, printers, and mouse, keyboard and webcam products.
Microsoft Wired Keyboard 600 - keyboard - UK - white Input Device
Keyboard
USB
Wired
Localization and Layout
Hot Keys Function
Multimedia, calculator, volume, mute
Spillproof
White
45.6 cm x 16 cm
Microsoft Certification
Compatible with Windows 7
Keyboard
USB
Hot Keys Function
Spillproof
45.6 cm
16 cm
White
1 x USB cable
Microsoft Windows XP SP2, Microsoft Windows Vista, Apple MacOS X 10.2 - 10.5
