This keyboard combines a spill-resistant keyboard with all the features you need - and more - with Microsoft quality and reliability. Enjoy plug-and-play setup and quiet touch keys with quick access to media controls and calculator.
Media center
Four hot keys let you control the most-used media activities (play/pause, volume up, volume down, and mute). -
Calculator hot key
With the touch of the button, you can quickly access the calculator. -
Spill-resistant design
Enjoy a drink while you work - this keyboard is designed to withstand an accidental spill. -
Plug and Play
No software needed. Just connect the keyboard to your PC and go! -
Device stage
Quickly and easily access common tasks, including product information, registration, settings and more for popular devices such as cell phones, cameras, printers, and mouse, keyboard and webcam products.
- Microsoft Wired Keyboard 600 - keyboard - UK - black Input Device
- Keyboard
- Interface
- USB
- Connectivity Technology
- Wired
- Localization and Layout
- UK
- Hot Keys Function
- Multimedia, calculator, volume, mute
- Spillproof
- Black
- 45.6 cm x 16 cm
- Microsoft Certification
- Compatible with Windows 7
- Keyboard
- Interface
- USB
- Hot Keys Function
- UK
- Spillproof
- 45.6 cm
- 16 cm
- Black
- Cables Included
- 1 x USB cable
- OS Required
- Microsoft Windows XP SP2, Microsoft Windows Vista, Apple MacOS X 10.2 - 10.5
