Microsoft Wheel Mouse Optical 1.1 5pack
Customer rating: 4.0* (Write a review)
Quicklinx: 3Z9MWS00 Mfr#: D66-00076
Get optical reliability at an affordable price. This optical mouse features a convenient scroll wheel, customizable buttons, and stylish design.
Optical technology refers to the use of an optical sensor to track mouse movement, rather than the traditional use of mechanical parts. As a result, optical mouse products work on most surfaces and offer you better durability, increased speed and accuracy, and consistent performance.
  • Optical technology
    Navigate with better speed, accuracy and reliability - the optical sensor tracks movement on nearly any surface without the hassle of clogged mouse parts.
  • Comfortable in either hand
    Use your mouse with your left or right hand - ambidextrous design makes it comfortable either way.
  • Scroll wheel
    Save time and effort with the scroll wheel - navigate documents and Web pages without using the on-screen scroll bar.
Microsoft Wheel Mouse Optical - mouse - PS/2, USB - black
Mouse
Packaged Quantity
5 (specifications are for single item)
Wired - PS/2, USB
Movement Detection Technology
Optical
Buttons Qty
3
Programmable buttons, scrolling wheel
1 x USB cable - integrated , 1 x mouse adapter - external
Apple MacOS X 10.1, Microsoft Windows NT 4.0 SP6 or later, Microsoft Windows 98/ME/2000/XP, Apple MacOS 8.6 - 9.x
Microsoft Certification
Compatible with Windows 7
Packaged Quantity
Mouse
Input Device
Wired
PS/2, USB
Optical
Buttons Qty
3
1 x mouse - generic - 6 pin mini-DIN (PS/2 style) , 1 x USB - 4 pin USB Type A
RoHS
Software Included
Microsoft Intellipoint
Additional Requirements
CD-ROM
System Requirements Details
Windows 98/ME - Pentium - 133 MHz - RAM 32 MB - HD 25 MB , Windows NT 4.0 - Pentium - 133 MHz - RAM 64 MB - HD 25 MB , Windows 2000 Pro - Pentium - 133 MHz - RAM 128 MB - HD 25 MB , Windows XP - Pentium - 233 MHz - RAM 128 MB - HD 25 MB , MacOS 8.6 - 9.x HD 15 MB , MacOS X 10.1 HD 15 MB
Customer reviews
Write a review for the Microsoft Wheel Mouse Optical 1.1 5pack here!
Good value for money
Reviewed by Nick. Review Posted 21/09/2007
About the most comfortable and easy to use mice for anything like this sort of money. The users like them and at about £8.80 ex VAT per unit they're not expensive.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Great Product
Reviewed by Ian. Review Posted 09/01/2007
Agred - For office use they're the best product on the market, however pricey for my liking. Fortunately my IT budget doesn't restrict me from buying cheap mice, so I'm about to order my 5th 5-pack of Black-Wired Optical Mice.
Great product, nothing else to say.
  • Overall 5*
  • Ease of use 5*
  • Value for money 4*
To the above...
Reviewed by Jason. Review Posted 27/07/2006
Uh, to the guy who thought £56 was a lot for a mouse:
You're right, £56 for a basic mouse is a lot of money. However, if you look real close at the item description, you'll see it's a 5 pack!
That aside, it's a bog-standard optical mouse. We use these at work, and they're accurate and comfortable, although there are a hundred optical mice out there that do that now, and for less than a tenner a pop, as well.
  • Overall 4*
  • Ease of use 5*
  • Value for money 3*
Read all 5 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
