The next-generation classic click-in keyboard for Surface is backlit to keep you working when the lights go down. Type Cover 2 is backlit so you can work in any lighting conditions. With the speed and comfort of a classic keyboard in a super-thin, lightweight design, you can truly work anywhere, anytime.
Work like you always have in even more places. Type Cover 2 has the speed and functionality of a classic laptop keyboard. It's backlit so you can continue working after the lights go out. Easy attach and disconnect lets you set up and get going right away.
Colorful, backlit mechanical keyboard
Work like you always have in even more places. Type Cover 2 has the speed and functionality of a classic laptop keyboard. It's backlit so you can continue working after the lights go out. Easy attach and disconnect lets you set up and get going right away. -
Windows shortcut, function, and media keys and trackpad
Windows shortcuts function keys, and media controls make it easy to navigate your Surface without taking your hands off the keyboard. Ultra-thin trackpad lets you control the cursor with your fingertip. -
Doubles as screen cover
Fold Type Cover 2 back like a book cover to get the full touch-screen experience. Type Cover 2 keys are disabled when the cover is flipped back. Close Type Cover 2 to shut down your display, and help protect the screen from bumps and scratches.
- Microsoft Surface Type Cover 2 - keyboard - charcoal
- Keyboard
- Backlit
- Hot Keys Function
- Volume, search, mute, play/pause
- Integrated trackpad, magnetic connection, accelerometer
- Charcoal
- 27.69 cm x 18.8 cm x 0.5 cm
- 255 g
- 1-year warranty
- Designed For
- Surface 2, Pro, Pro 2, RT
- Keyboard
- Backlit
Input Device
- Hot Keys Function
- Keyboard Technology
- Mechanical
- 27.69 cm
- 18.8 cm
- 0.5 cm
- 255 g
- Charcoal
- Limited warranty - 1 year
- Designed For
- Microsoft Surface 2, Pro, Pro 2, RT
