Microsoft Surface USB4 Dock - USB-C / USB-A - 2 x USB-C, HDMI - 1GbE - 100 Watt
Quicklinx: J3Z4WS00 Mfr#: EP2-19890
£133.39 ex VAT
£160.06 inc VAT
The Microsoft Surface USB4 Dock offers seamless connectivity and efficient power delivery for a variety of devices. With an integrated USB-C cable of 80 cm, this compact docking station features multiple interfaces including HDMI, dual USB-C ports, and Gigabit Ethernet. Enjoy high-definition clarity through 4K 60 Hz support while powering your devices with a 65 W power delivery capability. The dock supports dual monitor setups, making it ideal for productivity enhancements while providing preboot execution environment (PXE) support for added functionality. Designed with convenience in mind, the Microsoft Surface USB4 Dock allows for fast data transfers up to 40 Gbps. With a focus on reliable networking, the dock features a 1 Gb Ethernet port and ensures Wake-on-LAN functionality. Security is prioritized with a Kensington security slot, making it a robust solution for both office and remote work environments.
  • Efficient connectivity
    Featuring multiple ports including HDMI and USB-C, this docking station provides versatile connectivity to accommodate various devices and peripherals.
  • Dual monitor support
    Enhance productivity by connecting two monitors simultaneously, providing expanded screen real estate for multitasking.
  • Power delivery capability
    Equipped with 65 W power delivery, this dock allows for efficient charging of connected devices while in use.
  • High-speed data transfer
    Benefit from data transfer speeds of up to 40 Gbps, ensuring rapid file transfers and seamless performance.
  • Compact design
    The compact form factor of the dock makes it an ideal travel companion, fitting easily into any workspace setup.
Microsoft Surface USB4 Dock - docking station - USB-C / USB-A - 2 x USB-C, HDMI - 1GbE
Docking station
Docking Interface
USB-C / USB-A
Video Interfaces
2 x USB-C, HDMI
12 cm x 6 cm x 1.5 cm
206 g
Gigabit Ethernet
Power supply 100 Watt Power Provided
1-year warranty
Docking station
12 cm
6 cm
1.5 cm
206 g
Video
Max Resolution Details
4K - 60 Hz (Dual Display (HDMI + USB-C)) ¦ 8K - 30 Hz (Single Display (HDMI / USB-C))
Gigabit Ethernet
1 x USB 3.2 Gen 2 (7.5 W) - 9 pin USB Type A ¦ 2 x Thunderbolt 4 / USB4 Gen 3 (video / 7.5 W) - 24 pin USB-C ¦ Display / video - HDMI - 19 pin HDMI Type A ¦ 1 x USB-C (power port) - 24 pin USB-C ¦ 1 x network - 1Gb Ethernet - RJ-45
1 x USB-C cable - integrated - 80 cm
Security lock slot (cable lock sold separately), Preboot Execution Environment (PXE) support, dual monitor support, wake on LAN, up to 40Gbps data transfer, 65W power delivery (pass-through), MAC address pass-through, compact
Security Slot Type
Power supply
Power Provided
100 Watt
Windows
Limited warranty - 1 year
Brand: Microsoft
