Microsoft Surface USB to Ethernet Adaptor
Quicklinx: 966LWS00 Mfr#: Q4X-00004
The Surface USB to Ethernet adapter connects your surface pro to a network when Wi-Fi is not available.
Microsoft Surface USB to Ethernet adapter - network adapter - USB - 10/100 Ethernet
Network adapter
External
Interface (Bus) Type
USB
Ports
10/100 Ethernet
2.2 cm x 1.7 cm
Length
30.5 cm
24 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX
10Mb LAN, 100Mb LAN
1-year warranty
Surface Pro, Pro 2
Network adapter
External
USB
Ports
10/100 Ethernet
Wired
Cabling Type
Ethernet, Fast Ethernet
1 x 100Base-TX - RJ-45
2.2 cm
1.7 cm
Length
30.5 cm
24 g
Limited warranty - 1 year
Microsoft Surface Pro, Pro 2
