Microsoft Surface USB-C Travel Hub
Quicklinx: H30BWS00 Mfr#: 1E4-00002
£69.46 ex VAT
£83.35 inc VAT
The multi-port Microsoft USB-C Travel Hub gives you more ways to connect to networks, displays and USB-C accessories when you're on the go.
  • Versatile connectivity
    The Microsoft USB-C Travel Hub offers a wide range of connection options with its integrated USB-C cable, ensuring compatibility with various devices and peripherals. This hub simplifies the connection process, allowing for a seamless transition between workspaces without the need for multiple adapters.
  • High-speed data transfer
    Equipped with USB 3.2 Gen 2 ports, this travel hub provides fast data transfer speeds, making it easier to manage large files and reduce waiting times. Whether it's for work or leisure, the efficient data handling capabilities enhance productivity and entertainment experiences.
  • Comprehensive display options
    With both HDMI and VGA interfaces, the Microsoft USB-C Travel Hub supports multiple display setups, offering flexibility for presentations, conferences, or multi-monitor workstations. This feature ensures that users can connect to a wide range of display devices without compatibility issues.
  • Reliable network connectivity
    Featuring an RJ-45 connector for Ethernet 10Base-T/100Base-TX/1000Base-T, this hub provides a stable and fast network connection. It's ideal for locations with poor wireless connectivity, offering a reliable solution for uninterrupted work and streaming.
  • Compact and portable design
    The travel-friendly design of the Microsoft USB-C Travel Hub, with its 20 cm integrated cable, makes it an essential accessory for professionals on the go. Its compact size ensures it can easily fit into any laptop bag or carrying case, ensuring connectivity is always within reach.
Microsoft USB-C Travel Hub - docking station - USB-C - VGA, HDMI - 1GbE
Docking station
Docking Interface
USB-C
Video Interfaces
VGA, HDMI
4.8 cm x 8.9 cm x 1.5 cm
99.2 g
Gigabit Ethernet
Pricing Type
Commercial
1-year warranty
Docking station
4.8 cm
8.9 cm
1.5 cm
99.2 g
Enclosure Colour
Gigabit Ethernet
1 x USB 3.2 Gen 2 - 24 pin USB-C , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x USB 3.2 Gen 2 - 9 pin USB Type A , 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) , 1 x display / video - HDMI - 19 pin HDMI Type A
1 x USB-C cable - integrated - 20 cm
4K Ultra HD
Pricing Type
Commercial
Microsoft Windows 7 Professional, Google Chrome OS, Windows 8, Windows 10 Home, Windows 10 Pro, Android 8.1 (Oreo), Android 9.0 (Pie), Apple macOS 10.14.1 or later
Limited warranty - 1 year
Brand: Microsoft
