Write, sketch, navigate and recharge. Take handwritten notes and draw with the same feeling you get with pen on paper, with exceptional accuracy and a storable design.
The Surface Slim Pen 2 does not come with a charger. Surface Slim Pen 2 is compatible to charge with a wide variety of Surface devices. All are sold separately.
Sleek and comfortable
Slim carpenter-inspired style is perfect for all hands and is easy to hold and control. -
Easily erase and edit on the fly
Just flip it around as you would a traditional pencil. -
Better shading experience
A sharper pen tip and an improved design let you approach the screen at a perfect 77° tilt for ultra-precise shading and an exceptional pressure sensitivity. -
Exceptional accuracy, smoother flow, greater control
A redesigned sharper pen tip helps?you put a finer point on everything you do.
 - Microsoft Surface Slim Pen 2 - active stylus - Bluetooth 5.0 - matte black
 - Active stylus
- Connectivity Technology
 - Bluetooth 5.0
 - Matte black
 - 13.68 cm x 1.13 cm x 0.63 cm
 - 13 g
- Buttons Qty
 - 2
 - Eraser, Zero force inking, Microsoft Pen Protocol (MPP)
- Pricing Type
 - Commercial
 - 1-year warranty
- Designed For
 - Surface Hub 2S 50", Hub 2S 85", Pro 8, Pro 8 for Business, Pro 9, Pro 9 for Business, Pro X, Pro X for Business, Studio 2, Studio 2+ for Business; Surface Duo 2
 - Active stylus
 - 13.68 cm
 - 1.13 cm
 - 0.63 cm
 - 13 g
- Product Material
 - Plastic
 - Matte black
Input Device
- Interface
 - Bluetooth 5.0
- Buttons Qty
 - 2
- Pressure Levels
 - 4096
- Pricing Type
 - Commercial
- Technology
 - Lithium Ion
- Capacity
 - 0.171 Wh
- Run Time (Up To)
 - 15 hour(s)
 - Limited warranty - 1 year
- Designed For
 - Microsoft Surface Hub 2S 50", Hub 2S 85", Pro 8, Pro 8 for Business, Pro 9, Pro 9 for Business, Pro X, Pro X for Business, Studio 2, Studio 2+ for Business , Microsoft Surface Duo 2
