Write, sketch, navigate and recharge. Take handwritten notes and draw with the same feeling you get with pen on paper, with exceptional accuracy and a storable design.
The Surface Slim Pen 2 does not come with a charger. Surface Slim Pen 2 is compatible to charge with a wide variety of Surface devices. All are sold separately.
                Sleek and comfortableSlim carpenter-inspired style is perfect for all hands and is easy to hold and control.
                Easily erase and edit on the flyJust flip it around as you would a traditional pencil.
                Better shading experienceA sharper pen tip and an improved design let you approach the screen at a perfect 77° tilt for ultra-precise shading and an exceptional pressure sensitivity.
                Exceptional accuracy, smoother flow, greater controlA redesigned sharper pen tip helps?you put a finer point on everything you do.
- Microsoft Surface Slim Pen 2 - active stylus - Bluetooth 5.0 - matte black
- Active stylus
- Connectivity Technology
- Bluetooth 5.0
- Matte black
- 13.68 cm x 1.13 cm x 0.63 cm
- 13 g
- Buttons Qty
- 2
- Eraser, Zero force inking, Microsoft Pen Protocol (MPP)
- Pricing Type
- Commercial
- 1-year warranty
- Designed For
- Surface Hub 2S 50", Hub 2S 85", Pro 8, Pro 8 for Business, Pro 9, Pro 9 for Business, Pro X, Pro X for Business, Studio 2, Studio 2+ for Business; Surface Duo 2
- Active stylus
- 13.68 cm
- 1.13 cm
- 0.63 cm
- 13 g
- Product Material
- Plastic
- Matte black
Input Device
- Interface
- Bluetooth 5.0
- Buttons Qty
- 2
- Pressure Levels
- 4096
- Pricing Type
- Commercial
- Technology
- Lithium Ion
- Capacity
- 0.171 Wh
- Run Time (Up To)
- 15 hour(s)
- Limited warranty - 1 year
- Designed For
- Microsoft Surface Hub 2S 50", Hub 2S 85", Pro 8, Pro 8 for Business, Pro 9, Pro 9 for Business, Pro X, Pro X for Business, Studio 2, Studio 2+ for Business , Microsoft Surface Duo 2
