Create, study, work and play virtually anywhere. Better than ever, ultra-light Surface Pro gives you total mobile productivity, all-day battery life plus a softer, ultra-portable design with rounded edges.
Uncompromising mobility
Create, study, work, and play virtually anywhere. Better than ever, ultra-light Surface Pro gives you total mobile productivity, all-day battery life, plus a softer, ultra-portable design with rounded edges. -
Exceptional power and performance
Surface Pro delivers even more speed and performance thanks to a powerful Intel Core processor - with up to 50% more battery life than Surface Pro 4 and 2.5x more performance than Surface Pro 3. -
A vibrant display that inspires creativity
Watch your ideas come to life in brilliant color and razor-sharp resolution on the 12.3" PixelSense display with a stunning screen. -
Whisper quiet
Surface Pro i5 models feature a fanless cooling system, so you can work or stream your favorite shows in peace.
- Microsoft Surface Pro - 12.3" - Intel Core i5 - 7300U - 16 GB RAM - 256 GB SSD
- Product Type
- Tablet - no keyboard
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i5 (7th Gen) - 7300U / 2.6 GHz, up to 3.5 GHz / 3 MB Cache
- Memory
- 16 GB LPDDR3
- Storage
- 256 GB SSD
- Display
- 12.3" touchscreen 2736 x 1824
- Graphics
- Intel HD Graphics 620
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1
- Battery
- Up to 13.5 hours
- Accelerometer, ambient light sensor, gyro sensor
- Dockable
- Security
- Trusted Platform Module (TPM) Security Chip
- 29.2 cm x 20.1 cm x 0.85 cm
- 770 g
- Localisation
- Region: United Kingdom, Ireland
- Pricing Type
- Commercial
- Specific Absorption Rate (SAR)
- 0.867 W/kg (body)
- Limited warranty - 1 year
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i5 (7th Gen) 7300U / 2.6 GHz
- Max Turbo Speed
- 3.5 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- RAM
- 16 GB
- Technology
- LPDDR3 SDRAM
- Speed
- 1866 MHz
Storage
- Main Storage
- 256 GB SSD
Display
- 12.3"
- Touchscreen
- Yes (10-point multi-touch)
- Resolution
- 2736 x 1824
- Widescreen
- Image Aspect Ratio
- 3:2
- PixelSense
Audio & Video
- Graphics Processor
- Camera
- Yes - 1080p
- Resolution
- 8 Megapixel (rear), 5 Megapixel (front)
- Camera Features
- Autofocus, Windows Hello
- Sound
- Stereo speakers, two microphones
- Dolby Audio Premium
Communications
- Wireless
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.1
- Run Time
- Up to 13.5 hours
Connections & Expansion
- Interfaces Details
- USB 3.0 , Mini DisplayPort , Headphone/microphone combo jack , Dock , SurfaceConnect
- Memory Card Reader
- Yes (microSD, microSDHC, microSDXC)
Software
- Software Included
- Microsoft 365 (30 days trial)
- Integrated Options
- Dockable
- Security
- Studio Mode
- Included Accessories
- Power adapter
- SAR Value
- 0.867 W/kg (body)
- 0.867 W/kg (body)
- Localization
- Pricing Type
- Commercial
- 770 g
Sustainability Information
- TCO Certified
