The most powerful Pro
Surface Pro 8 combines the power of a laptop with the flexibility of a tablet, and every angle in between, with the iconic Kickstand and larger 13" touchscreen.
Most powerful Pro
Designed to deliver unprecedented levels of performance in an ultra-versatile package, Surface Pro 8 pushes the boundaries of what you expect from your computer.
Intel® Evo™ platform
Do it all with the first Surface Pro built on the Intel® Evo™ platform on selected configurations, engineered for mobile performance with 11th Gen Intel® Core™ processors, amazing graphics and all-day battery life¹ in a thin and light PC.
All-day battery
Stay connected to what matters all day with up to 16 hours of battery life and Fast Charging to go from low battery to full faster.
High-speed connections with two Thunderbolt™ 4 ports
Create your ultimate productivity setup with multiple 4K monitors, always have large creative files on hand with an external hard drive, or create a dream gaming setup with an external GPU
All in an ultra-portable design
At just 891 grams
Larger 13" touchscreen
Virtually edge-to-edge PixelSense™ Flow touch display, with up to 120Hz refresh rate
Pair with Surface Slim Pen 2, stored and charged^ in Surface Pro Signature Keyboard, for the natural feeling of pen on paper
11th Gen Intel® Core™ processor, Windows 11, and up to 32GB1 RAM
Create the ultimate productivity setup with Thunderbolt™ 4 ports
Multitask across Microsoft 365?apps and enjoy console calibre gaming
Laptop, tablet, or digital canvas
Set your perfect angle with built-in Kickstand that adjusts nearly 180 degrees
A real Keyboard — add Surface Pro Signature Keyboard* to type in comfort, with backlit keys and large glass touchpad
Ultra-portable design
More ways to connect
Built-in 5.0MP 1080p front-facing camera and 10MP 4K rear-facing camera
Two USB-C® with Thunderbolt™ 4 ports
Dedicated charging port
WiFi 6 for ultra-fast bandwidth
More screen, more speed
Individually calibrated and virtually edge-to-edge, the high-resolution 13" PixelSense touch display with up to 120Hz refresh rate is the most advanced Pro display. Touch and pen are more responsive. -
More power than ever
11th Gen Intel Core processors deliver power for intensive workloads, whether multitasking while on a video call or crushing a spreadsheet. Surface Pro 8 is the most powerful 2-in-1. -
Team collaboration without limits
Keep your team collaborating on a PC for remote work with high-definition connections. Employees stay connected and productive with this versatile 2-in-1 for business. -
Connect with fast, reliable Wi-Fi 6
Wi-Fi 6 delivers better performance in congested areas. -
Stay connected in high-definition
The built-in 5.0MP 1080p camera improves upon low-light performance, brightness, and skin tone accuracy. Dual Studio Mics make sure your voice is crystal clear. -
Capture, edit, share
Capture video footage in 4K, scan a document, or drop a photo into Microsoft Whiteboard and brainstorm in real-time with the 10MP rear-facing camera.
- Microsoft Surface Pro 8 - 13" - Intel Core i5 - 1135G7 - 8 GB RAM - 128 GB SSD
- Product Type
- Tablet - no keyboard
- Operating System
- Win 11 Home
- Processor
- Intel Core i5 (11th Gen) - 1135G7 up to 4.2 GHz / 8 MB Cache
- Memory
- 8 GB LPDDR4X
- Storage
- 128 GB SSD
- Display
- 13" touchscreen 2880 x 1920 @ 120 Hz - 267 ppi
- Graphics
- Intel Iris Xe Graphics
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac/ax, Bluetooth 5.1
- Battery
- Up to 16 hours
- Accelerometer, magnetometer, gyro sensor, ambient colour sensor
- Dockable
- Security
- Firmware Trusted Platform Module (TPM) Security Chip
- Platinum
- 28.7 cm x 20.8 cm x 0.93 cm
- 891 g
- Limited warranty - 1 year
- Product Type
- Operating System
- Windows 11 Home
Processor / Chipset
- CPU
- Intel Core i5 (11th Gen) 1135G7
- Max Turbo Speed
- 4.2 GHz
- Number of Cores
- Quad-Core
- Cache
- 8 MB
- RAM
- 8 GB
- Technology
- LPDDR4X SDRAM
Storage
- Main Storage
- 128 GB SSD
Display
- 13"
- Touchscreen
- Yes (10-point multi-touch)
- Resolution
- 2880 x 1920
- V-Sync Rate at Max Res.
- 120 Hz
- Widescreen
- Pixel Density (ppi)
- 267
- Image Aspect Ratio
- 3:2
- Windows Ink Capability
- Dolby Vision, PixelSense Flow, GPU ink acceleration, 60 Hz refresh rate (default)
Audio & Video
- Graphics Processor
- Camera
- Yes - 4K (rear), 1080p (front)
- Resolution
- 10 Megapixel (rear), 5 Megapixel (front)
- Camera Features
- Rear camera auto focus, Windows Hello
- Sound
- Stereo speakers, two microphones
- Dolby Atmos
Communications
- Wireless
- Capacity
- 51.5 Wh
- Run Time
- Up to 16 hours
Connections & Expansion
- Interfaces Details
- 2 x USB4 (supports Thunderbolt 4) (Type C) , SurfaceConnect , Headphone output , Dock
Software
- Software Included
- Microsoft 365 Family (30 days trial), Microsoft 365 Apps (requires licence or subscription), Xbox app, Xbox Game Pass Ultimate (1 month trial)
- Platinum
- Case Material
- Signature anodised aluminium
- Integrated Options
- Dockable
- Security
- Volume control, built-in kickstand
- Included Accessories
- Power adapter
- 891 g
Sustainability Information
- TCO Certified
Get more from your purchase from one of our essential accessories
Microsoft Surface Slim Pen 2 - Matte Black | In Stock | £89.66 |
