Surface Pro 4 goes from tablet to laptop in a snap, with the multi-position kickstand and improved keyboard.
Runs like a desktop, looks like a tablet - Microsoft's Surface Pro 4 is fast, slim and lightweight. Designed replace your laptop, the Pro 4 is installed with Windows 10 Pro and features a sixth-generation Intel Core m3 processor to make is more powerful and efficient to keep battery consumption low.
Powered by Intel
The Surface Pro 4 performs like a laptop thanks to its sixth-generation Intel Core m3 processor and 4GB of RAM. It can easily run multiple applications and programmes at the same time, to let you jump from your email to your music library and on to your photo albums.
Work anywhere
An integrated kickstand and huge battery life makes the Surface Pro 4 easy to take with you and use anywhere. Featuring multiple positions, the kickstand can be easily adapted to your situation, letting you work comfortably at a desk, browse with ease on the sofa or take in a movie on a plane. You’ll be able to use the Surface Pro 4 all day too, thanks to the battery which can last for up to 9 hours of web browsing. With such great battery life, you’ll find yourself tethered to a power socket less and enjoying the freedom to work where you please.
PixelSense display
With a resolution of 2736 x 1824 pixels, the Surface Pro 4’s 12.3-inch PixelSense™ display ensures high contrast and low glare to deliver a breathtaking picture. Bright, vibrant and full of details, the Surface Pro 4’s screen is ideal for watching movies and editing images. Touch screen technology will let you get hands on with your apps, while the new Surface Pen delivers the most natural and accurate writing and drawing experience yet, letting you take notes, mark up presentations, sign documents or get creative with art apps.
Photos, videos and sound Featuring a 5-megapixel front-facing HD camera and stereo microphone to make Skype calls to friends and family while you're on holiday and have video conferences with your colleagues on the other side of the world. The 8-megapixel autofocus rear-facing camera with 1080pHD video recording to capture all your magic moments.
A Full suite of connections
The Surface Pro 4 features the latest technology to help you connect with the rest of your technology. Built-in Wi-Fi that’s compatible with superfast ‘ac’ routers will let you hook up to your home network and browse the internet at your leisure. Bluetooth 4.0 LE will let you wirelessly transfer data and stream media to other Bluetooth devices without draining your battery, while a full size USB 3.0 port and micro SD card slot will let you hook your Surface up to other peripherals and storage devices. You can even connect your Surface Pro 4 to a monitor, TV on projector by using the Mini DisplayPort and a compatible cable.
Product Features:
Light and powerful: Surface Pro 4 turns from a tablet into a full powered laptop while running all of your desktop software.
Amazing screen: The 12.3" PixelSense display has extremely high contrast and low glare, giving you a picture rivaling real life.
Work on the go: With the multi-position kickstand and an improved Type Cover, it transforms into a fully functioning laptop running desktop software.
Exceptional performance: Surface Pro 4 is your mobile workstation, with powerful processors that allow you to run multiple programs.
Mobile workstation: Surface Pro 4 with fast processors is not only more powerful - it's quieter and runs cooler than ever before.
Stay sharp: Video conference in HD with the 5 MP front-facing camera or take stunning pictures and video with the 8 MP autofocus rear-facing camera.
Lasts all day: The battery lasts many hours so you can work uninterrupted. You can take your Surface with you all day.
Markup web pages: Write directly on web pages with Surface pen in the browser and share your notes easily.
Limitless apps: Surface Pro 4 has all the power you need for even the most demanding apps.
Rest your hand: With Palm Block technology you can rest your hand on the screen to write naturally, just like a pad of paper.
PixelSense: The PixelSense is a true-to-life screen technology designed for beauty, touch and pen.
On the go: The Surface Pro 4 Type Cover folds up or detaches so that you can use it anywhere.
Works the way you do: On a plane, on your lap, or dock it at your desk to turn it into a desktop PC.
- Microsoft Surface Pro 4 - 12.3" - Intel Core m3 - 6Y30 - 4 GB RAM - 128 GB SSD
- Product Type
- Tablet - no keyboard
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core m3 (6th Gen) - 6Y30 / 900 MHz (2.2 GHz) / 4 MB Cache
- Memory
- 4 GB
- Storage
- 128 GB SSD
- Display
- 12.3" touchscreen 2736 x 1824
- Graphics
- Intel HD Graphics 515
- Input Device
- Surface Pen
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac
- Battery
- Up to 9 hours
- Accelerometer, ambient light sensor, magnetometer, gyro sensor, hall sensor
- Dockable
- Security
- Trusted Platform Module (TPM) Security Chip
- Silver
- 29.21 cm x 20.142 cm x 0.845 cm
- 766 g
- Localisation
- Region: United Kingdom, Ireland
- Pricing Type
- Commercial
- SAR
- 0.773 W/kg (body)
- Limited warranty - 1 year
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Intel Core m3 (6th Gen) 6Y30 / 900 MHz
- Max Turbo Speed
- 2.2 GHz
- Number of Cores
- Dual-Core
- Cache
- 4 MB
- 64-bit Computing
- RAM
- 4 GB
Storage
- Main Storage
- 128 GB SSD
Display
- 12.3"
- Touchscreen
- Yes (10-point multi-touch)
- Resolution
- 2736 x 1824
- Widescreen
- Image Aspect Ratio
- 3:2
- PixelSense
Audio & Video
- Graphics Processor
- Camera
- Yes - 1080p
- Resolution
- 8 Megapixel (rear), 5 Megapixel (front)
- Camera Features
- Autofocus, Windows Hello
- Sound
- Stereo speakers, stereo microphone
Input
- Surface Pen
Communications
- Wireless
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac
- Run Time
- Up to 9 hours
Connections & Expansion
- USB 3.0 ¦ Mini DisplayPort ¦ Headphone/microphone combo jack ¦ Dock ¦ SurfaceConnect
- Memory Card Reader
- Yes (microSD, microSDHC, microSDXC)
Software
- Software Included
- Microsoft Office (30 days trial)
- Silver
- Case Material
- Magnesium alloy
- Integrated Options
- Dockable
- Security
- SAR Value
- 0.773 W/kg (body)
- Localization
- Pricing Type
- Commercial
- 766 g
