Designed to match the look and feel of your Surface Pro 3, the 36-watt power supply provides power when you need it.
Magnetic connector
Magnetic snap-in power adapter charges your Surface Pro 3. -
Slender form factor
Slender cord and adapter allow access to outlets behind furniture or in other tight spaces. -
Additional USB port
Plug your phone or headset into the USB 2.0 port to keep your other devices charged and ready to go at the same time as your Surface Pro 3.
- Microsoft Surface Pro 3 Power Supply - power adapter - 36 Watt
- Power adapter - external
- 168 g
- Localisation
- United Kingdom, Ireland
- Power Capacity
- 36 Watt
- Output connectors
- 1 x power , 1 x 4 pin USB Type A
- 1-year warranty
- Designed For
- Surface Pro 3
- Localisation
- Power Output Connectors Details
- Power Capacity
- 36 Watt
- Cables Included
- Power cable
- Limited warranty - 1 year
- 168 g
- Designed For
